slim to none, it is all tight in terms of looks but also space
hadnāt updated the list yet, it is done now
Well a way to cope with the waiting for news was several projects as one, increasing the chance of something happening in one. Yesterday however all three were buzing with nws and communications, pics, videos, emails, all rapidly on diverse subjects. Yeah that would not be good to have all day normally it is all good thought
It is tight bu twe are looking at a
AT85 MCU
FET + 1 + 7
1 7135 for lowest modes from moon and up to 350mA
then the extra 7 7135 kick in for regulated output of 2800mA (I estimate ittle over 1200 lumens out the front but a no expert )
Tail switch instead of side switch. (both momentary electronic switches)
3 emitters instead of 4.
FET+7+1 driver instead of FET+1 (so, more efficient and higher regulated modes).
Narsil UI instead of Ramping IOS UI.
Different body style.
Extra pin wired up for aftermarket light-sense hacks.
At a guess, probably ~140 lm on the ā1ā channel, ~1000 lm on the ā7+1ā channels, and ~3000 lm on the FET channel. With smooth ramping from moon all the way to maximum. Or discrete levels if you prefer.
Anything up to 1000 lumens should be reasonably well-regulated.
Iām assuming I should (or someone should) probably put in some proper thermal regulation before the FW3A is released, but that probably wonāt be too hard.
Putting in a blink at channel boundaries shouldnāt be hard either, but it depends on if that feature is desired.
