Please, if is possible, I’m in for one.
In so hard
Can you put me down for 2 please?
A couple of times welcome to BLF!
Will update list later
Thank you the Miller
Please put me down for 2 lights
Thanks
Slow
Damn im late, but still in!
Count me in for one. Thanks!
In for 1 please!
I will go in for 1 of these as well. Thanks Miller!
Put me in for one, please!
Would love to be on the list thanks!
One needed, thanks…
I looked quick, but didn’t see… What’s the driver? FET? Approximate lumens and amps?
Put me in the list for one.
me to please.
It is tight bu twe are looking at a
AT85 MCU
FET + 1 + 7
1 7135 for lowest modes from moon and up to 350mA
then the extra 7 7135 kick in for regulated output of 2800mA (I estimate ittle over 1200 lumens out the front but a no expert )
Welcome to BLF new members!
Will updatelist later
This should be fairly similar to the D4, except:
- Tail switch instead of side switch. (both momentary electronic switches)
- 3 emitters instead of 4.
- FET+7+1 driver instead of FET+1 (so, more efficient and higher regulated modes).
- Narsil UI instead of Ramping IOS UI.
- Different body style.
- Extra pin wired up for aftermarket light-sense hacks.
At a guess, probably ~140 lm on the “1” channel, ~1000 lm on the “7+1” channels, and ~3000 lm on the FET channel. With smooth ramping from moon all the way to maximum. Or discrete levels if you prefer.
Anything up to 1000 lumens should be reasonably well-regulated.
I’m assuming I should (or someone should) probably put in some proper thermal regulation before the FW3A is released, but that probably won’t be too hard.
Putting in a blink at channel boundaries shouldn’t be hard either, but it depends on if that feature is desired.
Please add me to the list.
Hi, please add me to the list for one.
Thanks!
