Well it’s also #1 for LED flashlights that are available on the market
Guinness apparently didn’t take Ra’s Maxablaster submission because it wasn’t a retail flashlight.
If I ever build a light that makes the top 3, I will call it _blaster
Will update asap.
Unfortunately the Hyperblitz and the Zielscheinwerfer won’t make it on my list since they are both tethered, not “portable”.
If people want to see those lights they can go to your document instead
You’re right, I was looking at the wrong images that weren’t the hyperblitz.
I’m not sure if the Zielscheinwerfer counts as “portable” based on the guidelines I mentioned at the start, do you think it can be carried in one hand for many minutes with the ballast and batteries and everything?
Looks a bit too heavy to me, but idk.
I assumed that the moon blaster was battery powered and portable if it is only 120W, but without images it is hard to be sure.
I will have to look into it.
Updated again, this time a few more lights were added such as the “BLF GT” and “HID Scheinwerfer”
The_Driver still holds the record for a single-LED reflector thrower at 1.5Mcd but the BLF GT is very close
When people start modding the GT with Black Flat or Synios LEDs we will probably see 2Mcd+
From browsing the german forum of course that’s how I found the HID Scheinwerfer. And the other two as well.
I think I also have to add the TN42vnM which is at 1Mcd
