Review request for HKJ [USB Power Devices]
639 posts / 0 new
Barkuti
Barkuti's picture
Last seen: 2 hours 18 min ago
http://www.gearbest.com/nillkin-adapter-_gear/
http://nillkin.org/accessories/chargers/
Asked GearBest staff about this strange “Nillkin Travel Power Adapter Dock”, as in the advertisement “Support 2.0A Quick Charge” is claimed.
Synopsis:
GearBest Customer Service wrote:
Your original question is "Is this a Qualcomm Quick Charge compatible charger? 2.0? Specs seem strange, what's the difference between this charger and http://www.gearbest.com/chargers-cables/pp_488880.html ? Thank you. Regards, Salvador"
Here is the answer from Our Customer service Team:
Hello Salva,
Yes.It's Qualcomm Quick Charge compatible charger 2.0.
Weird.
The Light Innocent I am
HKJ
HKJ's picture
Last seen: 43 min 42 sec ago
Barkuti wrote:
Weird.
If it is this one you mean: http://www.gearbest.com/chargers-cables/pp_630687.html
It looks like the quick charge is only a reference to 2A current capabilities, not to any QC standard.
vidramon
More Liitokala cheap chargers for review Smile
maukka
maukka's picture
Last seen: 26 min 36 sec ago
Qidian QD188.
8×18650 power bank with adjustable dc out. Does not come with batteries. The construction looks cheap as hell, but I’m interested how would it fare in your tests.
Or would it be too similar to the 6×18650 Qidian you tested earlier?
TheBo
TheBo's picture
Last seen: 3 weeks 1 day ago
maukka wrote:
"Qidian QD188":https://www.aliexpress.com/store/product/Voltage-Regulating-QD-Laptop-Po.... 8x18650 power bank with adjustable dc out. Does not come with batteries. The construction looks cheap as hell, but I'm interested how would it fare in your tests. Or would it be too similar to the 6x18650 Qidian you tested earlier?
interested too... and i was about to provide the same link on aliexpress, but than i saw maukka had already provided everything
Rufusbduck wrote:
Getting discouraged is normal but doesn't finish the job.
maukka
maukka's picture
maukka wrote:
Qidian QD188.
Got it today. First impressions are good. With 4x NCR18650B I got 40.5 Wh out of the DC output at 12V / 2A. That’s about 90% efficiency.
TheBo
TheBo's picture
Oh... Lol... So you didn't wait his review...
I know you have quite an impressive equipment for testing color rendering, but I do not remember if you have an oscilloscope... Maybe yes, I recall some rigor stuff,too lazy now.... Sorry...
 I was curious about the Vripple, on load, V drop etc...
maukka
maukka's picture
Voltage drop
USB1
No load: 5.32V
0.5A: 5.26V
1.0A: 5.20V
1.5A: 5.16V
2.0A: 5.11V
2.5A: 5.07V
Shuts off above 2.7A
USB2
No load: 5.27V
0.5A: 5.16V
1.0A: 5.09V
1.5A: 5.04V
2.0A: 5.00V
Shuts off above 2.4A
DC 12V (voltage measured after bundled cable at a dc-adapter)
No load: 12.09V
0.5A: 12.02V
1.0A: 11.96V
2.0A: 11.84V
3.0A: 11.71V
DC 5V
No load: 5.09V
0.5A: 5.03V
1.0A: 4.94V
2.0A: 4.79V
3.0A: 4.65V
Couple pictures from the inside:
http://imgur.com/a/O28mZ
TheBo
TheBo's picture
maukka wrote:
Voltage drop..
Nice THANK YOU. I see you were able the push out 35W at ~12V... Nice there.
I wonder how close can it get to The "Chinese specs" that claim 60W @12V? 80W @16V
And between 88 and 89.7W theoretically for the other voltages.... Hmm... Seems an impressive piece of kit.
Also did you manage to test other random custom voltages at no load or at load?
P. S. ... Nevermind , Sorry This post became strange asking too much... Don't worry thanks for the thorough infos you already provided.
maukka
maukka's picture
Could have probably done more than 35W, but didn’t want to push it with just 4 batteries.
angerdan
angerdan's picture
Last seen: 6 hours 9 min ago
Hello HKJ, this Charger looks interesting and has 6× 2.4A:
BlitzWolf 50W Smart 6-Port High Speed Desktop USB Charger With Power3S Tech For iPhone iPad Samsung | BlitzWolf.com
https://www.blitzwolf.com/BlitzWolf-50W-smart-6-port-high-speed-desktop-USB-charger-with-power3S-tech-For-iPhone-iPad-Samsung-p-25.html
https://www.banggood.com/BlitzWolf-BW-S4-50W-Smart-6-Port-High-Speed-Des...USB-Charger-For-iPhone-iPad-Samsung-p-1020794.html
maukka
maukka's picture
I put in 4x Panasonic NCR18650B and 4x LG F1L after I tested that they had pretty much identical internal resistance and capacity. The power bank is configured in 4S4P and I inserted one Panasonic and one LG to each parallel pair so at least every series component was as close to identical as possible with this mixed set.
After successfully charging a Macbook Pro at 30-60 watts for about an hour and output about 41Wh (measured with a PortaPow), I tested the voltages of the individual cells as:
1S
1P 3.755 V (F1L)
2P 3.755 V (18650B)
2S
3.751 V
3.752 V
3S
3.753 V
3.753 V
4S
3.752 V
3.752 V
TheBo
TheBo's picture
Thank you! they are well matched. Nice
Barkuti
Barkuti's picture
Cells properly connected in parallel auto-balance automatically. In fact, you can combine different cells in each parallel array successfully:
The smaller cells are 10+C rated vs the 50As at 4C. This means the smaller cells will only provide 10 - 12% of the torque during a long sustained load, but provide more than 25% extra cold start torque, which is quite good for a low gear ratio drill mostly used to behead bolts (LoL!).
Trounces stuff with 10mm bits, tested. Wink
maukka
maukka's picture
TheBo wrote:
 I was curious about the Vripple, on load, V drop etc…
There’s two USB ports on the thing. For reference, on the Omnicharge (similar adjustable power bank) I measured 126 mVp-p and 22 mVrms from its USB ports at 1A. On the QD188 USB1-port I got 310/90 mV, USB2-port was ridiculously bad at 1800/410 mV (yep, that’s 1.8 volts peak to peak). Not much difference between 1 and 2 amp load.
I don’t have a very good cable setup for measuring ripple from the dc out, but at 12V/1A the QD188 was about the same as the Omnicharge at 356 mVp-p and 106 mVrms.
edit: disclaimer, the batteries on the QD188 were almost empty when I did the test
edit2: was able to bring down the noise a bit on the QD188 USB2 (1800mV to 800 mV) by using a different usb power bank to power the ZL1100 load. Should probably use a resistor instead to eliminate all other possible source of noise.
TheBo
TheBo's picture
Oh thank you. Is that a ds1054Z you used to test ripple?
Mmm maybe I am going too off topic. If I am correct, may I write you a PM, just in case I have some questions about it?
d_t_a
Last seen: 1 day 10 hours ago
review request:
I noted there has sprung up a number of USB power meters lately:
a) Satechi USB-C power meter (I think someone may have mentioned this already – for USB type-C only)
https://www.amazon.com/Satechi-Multimeter-Chargers-External-Capacity/dp/...
b) King Meter Power-Z KM001 (Std and Pro versions) USB power meter [the item looks very similar to YZXStudio’s model ZY1276]
Power-Z KM001
https://www.aliexpress.com/item/KINGMETER-Power-Z-High-Speed-USB-Voltage-Ammeter-QC-PD-Decoy-Coulometric-Meter-TYPE-C-Test/32816157844.html
or (the link below contains link to the item’s software download and manual; the software is still ‘beta’ or more likely ‘alpha’ stage; I tried downloading and running the software [without having the USB power meter] and the software is a mix of English and Chinese, on my English Windows 10)
https://www.aliexpress.com/item/POWER-Z-USB-tester-QC3-0-PD-Digital-voltmeter-amperimetro-Digital-voltage-current-amp-volt-Type/32820662689.html
[update: seems like there is a Power-Z KM001 and a Power-Z FL001; the Power-Z FL001 looks like a clone of the ZY1276; but YZXStudio seems to start to announce a new smaller sized ZY1275 that looks to be a clone of the Power-Z KM001 —- these are just my guesses based on the scant info (for now) I’ve seen while browsing around]
(there’s a review/first look (in Chinese, but lots of pictures) of the Power-Z FL001: http://www.chongdiantou.com/wp/archives/16142.html and the Power-Z KM001: http://www.chongdiantou.com/wp/archives/16818.html including both KM001 & FL001 being used to test a RavPower 26000mAh power bank: http://www.chongdiantou.com/wp/archives/16623.html)
ZY1275
c) Kotomi (Plus and Pro versions) USB power meter
https://www.aliexpress.com/item/Kotomi-high-precision-TFT-USB-current-voltmeter-QC-PD-trigger-PD-test/32819095841.html
– or – (the description of the link below has more detailed references; the feedback section of the link above has an English translation of the features comparison table)
https://www.aliexpress.com/item/Kotomi-Pro-High-Precision-Color-USB-Current-Voltage-Meter-Capacity-Coulometers-PD-QC-Trigger-Line-Resistance/32817004758.html
For Power / Energy logging, I had a VoltCraft Energy Logger 3500 for a few years now, I wonder how it compares with the ZhuRui PR10 Power Recorder. But it seems the VoltCraft Energy Logger is not being sold anymore…
HKJ
HKJ's picture
Thanks, I will be looking on some of these meters.
Now I also needs a real usb-c power supply with 20V 5A, anybody have a good idea where I can find one.
With power/energy meters I prefer to test currents ones, I have publishes a test of one more and I have one more in queue.
angerdan
angerdan's picture
How about these 87W power supplies:
https://www.amazon.de/dp/B01MQB29GV/
https://www.amazon.de/dp/B071KSKDFJ/
Anker already offers 60W:
https://www.anker.com/products/variant/PowerPort-Speed-1-USB-C-Port/A2015111
I found a powerbank with 100W USB-C:
https://www.indiegogo.com/projects/lifepowr-a3-world-s-1st-usb-c-power-d...
There’s a review of USB-C power supplies in the german c’t magazine:
https://www.heise.de/ct/ausgabe/2017-6-Vier-Steckernetzteile-mit-USB-C-Buchse-im-Vergleich-3635812.html
HKJ
HKJ's picture
The Apple one is the most interesting one, but I am lacking more detailed specifications.
The c’t looks (You have to pay for the full article) to be about the same usb-c types I have been reviewing, not the smart ones.
angerdan
angerdan's picture
HKJ
HKJ's picture
That is not what I am looking for. I has to be a USB Type-C charger with 100W, not a Quick charger or docking station (That delivers power on some other connector).
angerdan
angerdan's picture
I don’t understand why output has to be 100W, yet there are no known devices which can request 100W power.
HKJ
HKJ's picture
It do not need to, but for testing it would be nice to cover the full usb-c power range. I nothing better shows up I will probably start with the Apple.
angerdan
angerdan's picture
Would be interesting Smile
Found another USB Type-C voltmeter:
https://www.amazon.co.uk/Plugable-Amperage-Direction-Indication-Construc...
And thanks for the now brand new JustMobile AluCharge review Wink
L4M4
L4M4's picture
Last seen: 1 day 3 hours ago
How about:
https://www.aliexpress.com/item/CY-USB-3-1-Type-C-USB-C-Female-to-DC-5-5-2-5mm-Power/32468388154.html?
+ a 20A 5V Meanwell-Power-Supply?
HKJ
HKJ's picture
L4M4 wrote:
How about: https://www.aliexpress.com/item/CY-USB-3-1-Type-C-USB-C-Female-to-DC-5-5-2-5mm-Power/32468388154.html? + a 20A 5V Meanwell-Power-Supply?
What I want is something that understand and reacts to the usb-c commands for power delivery. This is much more complicated than Quick Charge and not something I want to make myself.
angerdan
angerdan's picture
Hi, i did find some new and interesting devices (usb power supplies/chargers).
Could be interesting for your queue Smile
Most interesting would be your review of the YZXStudio Power Bank:
http://budgetlightforum.com/node/48561
Powerbank which delivers 3A/5V via USB-C:
https://sandberg.it/da-dk/product/Powerbank-10000-USB-C-Plus-QC-3.0
USB charger with reversible plugs (so work with every cable besides the reversibled ones like fom Blitzwolf)
http://www.raidsonic.de/en/standards/searchresults.php?we_objectID=3559
USB charger with integrated Current and Voltage meter for 1/4 ports (1x QC2.0)
http://www.raidsonic.de/en/standards/searchresults.php?we_objectID=3373
USB charger with current and voltage meter for every of each 6 2.4A Ports:
https://www.amazon.de/dp/B01N07MW4G/
12V car USB charger with very slim case:
https://www.sandberg.it/da-dk/product/Mini-Car-Charger-USB-2100mA
d_t_a
Saw another energy/power meter from ZhuRui-Tec:
LPT200 Lamp Parameter Tester (the name says it’s designed to test LED lights, but the item’s description notes that it can be used to test electrical consumption of most electric appliances)
https://www.aliexpress.com/item/LPT200-LCD-TFT-lamp-tester-AC-power-meter-2500W-power-energy-kwh-voltage-current-substitute-for/1564283122.html
chrisc
I bought this one a few weeks back and was rather annoyed when I got it. Plug in my Nexus 6P, plug in my USB-C supply and it’ll show ~1.7A and wont “fast charge”. The phone realises something else is in line and doesn’t fast charge. Annoying.
https://www.banggood.com/JUWEI-2-in-1-Type-c-USB-Safety-Tester-Multifunctional-USB-Detector-Voltmeter-Ammeter-Capacity-Power-Impedance-Temperature-Power-Bank-Charger-Indicator-p-1163538.html?rmmds=search
