I’m now worried that mine would suffer the same fate. So far it’s still OK. I just keep it in my sling bag as an emergency light.
Nitecore products aren’t cheap and therefore we expect better quality than this.
I own a lot of Nitecore products and for the most part, have been very pleased with what they offer. This one, however, is a dud. Not the light and it’s electronics (which I really like) but the hinge system and the fact that they tried to pass it off as my fault.
I suspect that more and more people will discover this issue with the light. Hopefully Nitecore will wake up and come up with a fix.
Thanks for letting us know. My NU30 is still intact and as good as new.
Mine also broke today just by checking it. One of the hinges broke, also the plastic around is cracking. Idk if I wanne pay shipping for spare parts that most likely will break again. I’ll send them a mail with pictures anyway.
Nitecore charged me $5 US shipping and sent out 2 strap-side pieces, one of which (as I stated in my OP) has already broken. The idea of having to continually purchase replacement pieces every month or so for $5 is ludicrous. Clearly a flawed design. My NU20 (which I EDC and actually USE everyday) shows no signs of breaking. The hinge on it is more like the Fenix in tatasal’s pic.
You’re very welcome. I really think this is a poor design and that Nitecore is going to experience a lot of issues with it. The question is, what will they do? I’m hoping for a redesign of the strap-side piece to address the breakage.
Please don’t let me down, Nitecore.
Hi Mkduffer
Thanks for the heads up on the potential flaw
Like others have mentioned, I only have the NU20 which is used nightly for bed reading and is going great guns
I also stocked two with broken holders, not used, only. 2 months old.
Have tried with glue, but does not hold.
Ouch.
This is bad.
It’s like buying a disposable headlamp :person_facepalming:
Wow! That’s horrible! At this point, I’m not even using the light for fear of breaking the last piece I have. I hope they step up to the plate and work out a fix! I’m going to try to use some JB Weld or 5 minute epoxy to support the piece, but that will leave an unsightly bump.
No problems with mine so far. I have the green one. Wonder if the plastic is somehow tempered different. So far, the only ones I’ve seen cracked or broken are the black models.
What about NU10 and NU20?
I don’t have an NU10 so can’t say. As for my NU20, the hinge mechanism is different and does not appear to be prone to the fatigue which seems to plague the NU30.
Only my NU30 is affected the NU20 has no errors
You’re welcome. I love my NU20 as well. Bought the NU30 because of it’s longer run time, more versatility and higher output AND the side mounted USB charge port, which would allow running it while charging. The bottom mounted charge port on the NU20 doesn’t allow you to practically wear and charge the unit. The NU20 hinge seems much more robust and it’s light weight makes it easy to EDC. Been using it every day with no issues, so far.
Both NU30 and NU10 still new. hopefully its won’t happen to me.
I’m more on NU10 due to arm level work.
Anyone else having issues with the hinge of their NU30?
Same exact issue for me! Used only a dozen times at most. The hinge kept getting looser until one night it went completely floppy. Then when I got home, dropped it from waist height and the hinge shattered and headlamp came off. What a piece of sheeet!
Of course this wouldn’t happen with the NU20 as this is lighter/ smaller which would create much less wear or force on the hinge.
Unless they have changed the design, I suspect this will happen with all NU30 (unless other color plastic made better).
Total junk and wrong that you have to pay ANY shipping cost for replacement parts.
Nitecore charged me $5 (shipping only) for 2 back pieces. Yes, it was nice of them to charge me only shipping, however since I suspect this is either a design flaw or materials issue, that really puts it on them. Furthermore, after receiving my replacement pieces, the first replacement broke within a few weeks of use. It’s not like I’m trapezing around in the woods every night for 8 hrs at a time with the unit strapped to my head. I periodically check the property for 15-20 minutes 3-4 times a week. I’m afraid to use my final back piece for fear of it breaking. Not exactly a reliable piece of kit that I can have confidence in when the chips are down.
Almost immediately after receiving my replacement hinges, the first one broke. Afraid to use the second one, my NU30 has sat idle for nearly the past year. Sad.
I get that this is my fault for not following up, so I’ve reached out to Nitecore again, to see if they have done anything to resolve the issue. I’m hoping they have started using different materials, but I’m not holding my breath. Taking RobertB’s advice (liked your old avatar better, FWIW), I’ve asked that in lieu of a materials/design change, if they could possibly provide me with hinges of a different color, as RobertB has reported no issues with his green unit.
In the interim, it pains me to see the NU30 just sitting on my desk, unusable so I’ve come up with a possible fix. Parts needed are a tube of superglue, a pair of scissors and an old credit card. It turns out that if you cut a strip from your typical credit card, then cut it in half, it’s just about the perfect length for the fix I have in mind. It’s not terribly technical so I’m just posting a pic of the “fix”. Note: This is just a short term fix. It appears that the black hinges are made of particularly brittle plastic and if that is the case, it is just a matter of time before the rest of the hinge unit begins to crack as well. Come on, Nitecore, please step up to the plate!
Some basic advice: If your piece is already broken, I’d glue the tab back on first, then do the credit card thing later. Also, when doing the credit card, I found it useful to put some curvature into the card before gluing it. It allows the credit card to better fit the shape of the bracket. After fixing my tab, I laid down a thin line of super glue on the bracket, then attached the credit card strip. I’m letting the glue dry completely so haven’t tested it yet. I’ll post as to the success/failure once I’ve used the light.
On a personal note, I’ll never purchase another NU30 again. Also, while I’m a big fan of Nitecore products, their lack of action regarding this issue concerns me greatly and makes me think I might need to start looking at other manufacturers, people who have better design ideas, listen to their customers and stand behind their product. As an example, take the NU25. Looks to me like they stuck with the hinge design of the NU20, which makes sense, but is almost a tacit admittance that the hinge of the NU30 is flawed. That being the case, why did they not follow the request of many users and place the USB charge port to the side, where it could be used WHILE wearing the headlamp? It seems quite half-assed to me that they didn’t address this issue.
Oh well. Stepping off my soap box now.
