Ok. i hope i'll explain my self.
Richard has divided suitable batteries for this light in 2 groups.
- maximum performance
- best ratio between very very good performance and duration
NOTE: the batteries in maximum performance are IMR type, usually battery with the highest possible current delivery have low (or nowadays is more correct to say a bit lower) capacity than normal batteries. Since few years ago they were around the 2500mAh mark (LG HE2, Samsung 25R, Sony VTC5 etc..). Differently high capacity batteries at the time were Panasonic NCR18650 which were 3400mAh but the current they delivered was much lower. And they were suited for let's say for max 4-5A, maybe less. If you ask a battery more current than what it is designed for, battery can act in different ways, probably, voltage will sag (a lot, current will still be capped, so you wont' go any higher anyway, and you end with a lot of disappointment. Now since the 18650 is the most interested by evolution, the highest power delivery batteries are 3000mAh (LG HG2 and Samsung 30Q). You should find these in richard'sm maximung performance along with the previously mentione d 2500mAh type. This is nice because now the difference is not a lot compared to time ago with the highest capacity ones. Beware that there's also another important thing to notice. When you ask for a lot of current a battery will drop is voltage directly correlated to how much current you ask "her".
See this graph http://lygte-info.dk/review/batteries2012/Common18650comparator.php if you play selecting and deselecting currents you'll see that SAnyo 18650GA behave the same as Samsung 30Q at 1 A but Sanyo runs much longer, if you select 15A you'll see this behavior changes a lot .
Also the capacity a battery has varies with the current you ask "her" so ...a Sanyou 18650GA could well have real 3250mAh at1A draw, and a samsung just real 2900mAh, but the sammy retains almost 2700mAh at 15A draw, almost like the SANYO, but if you look at the 30Q the voltage in the samsung is much highe, thus giving you much power (power = Voltage * current)
Batteries in group 2 are still very nice because of what i just said, but since batteries with high current delivery have also less internal impedance you will squeeze till the maximum lumen just with group 1 batteries, althought with group 2 you will run longer, i don't know how much visual difference you will get to your eyes, maybe negligible, maybe not negligible... it's up to you, if every minutes count or not....what you use YOUR light for and what you planned to use YOUR batteries for...i think this is the fun stuff with this, and that's why people on this forum is so addicted and enjoys themselves.
Hope you got your explanation.
For the others, SORRY GUYS for this post.
TK , hank and Richard ..thanks for the light... I'm a bit under money now (tew thousand euros for the dentist) and i'm struggling with the monkey on my shoulder that slaps my face telling me to buy this in grey nichia....
