Review and disassembly: Sofirn SF36
30 posts / 0 new
XXX-Man
XXX-Man's picture
Last seen: 18 hours 53 min ago
Hello.
This is my first ever flashlight review so I will try my best Smile
Flashlight was provided from Sofirn with 99% discount. My review won't be affected by price.
Specification from manufacturer:
LED: Cree XP-L2 V6-2A-D, 1100 Lumen, 5350-5700K, 11200cd
Operating voltage: 2.8-4.2V
Battery: 1x 18650 Battery
Switch: backward tail clicky
Size: 13.2cm length, 2.5 / 3.2cm diameter, 118g (without battery)
Material: 6063 Aircraft aluminum with Type III anodization
Reflector: smooth
Battery warning: Blinks every 2 sec. And turns off one minute later
Deep discharge protection: yes, at 2.8V
Lens: Hardened glass lance with AR coating
Waterproof: IPX-8 (2 meters for 30 minutes)
PWM frequency: 20kHz
Strobe: 6 / 12Hz
5 Mode: High 1100lm 1h28min; Mid 300lm 4h15min; Low 50lm 18h; Firefly 1lm 147h; Strobe 1100lm 2h56min;
Mode Memory: yes
Tail-stand: yes
Package:
Sofirn SF36, 18650 2800mAh battery, USB charger with 70cm cable, manual, belt clip, 2x o-ring, lanyard
 Flashlight has nice feel and looks good quality.
Threads are square but little thin. They are anodised and came well lubricated.
Tube is not reversable.
Tail switch is reverse clicky mounted on 17mm board. It has nice click, but maybe little soft feeling (very easy to press, compared to others)
Flashlight can tailstand, but was not perfect na was wobbly. I cut 1mm from center of rubber tailcap and now perfect.
Driver is 19mm, but you could put 21mm with no problem. It's fixed with retaining ring.
Wires to LED are 24AWG
It has 4 modes with memory and strobe on double click. Modes are nicely spread.
Head has SS bezel. Glass is 27x2mm AR coated and reflector is SMO. AR coating is very light, but it's there.
There is o-ring between glass nad reflector and reflector has groove for o-ring to sit nicely.
LED is XP-L2 and is on 17x1,6mm copper board.
There is 1 screw holding board to shelf. Shelf is fixed, so no pill.
There is good amound of thermal paste between board and shelf.
Flashlight is 132mm long, diameter is 25,5mm at tail and 32,5mm at head.
Beam has some rings in it, not sure what is the reason.
Charger is Thorfire branded, with micro USB input.
It charges to 4.19V (if my multimeter is correct).
Battery is Sofirn branded, with protection. It came with protection sticker on + side.
Tested capacity with Lii-500 is 2628mAh so not that bad.
Some comparison pictures with Thorefire VG10 and Convoy S2+
Current measurements:
Cheap dmm, not sure how accurate it is so I made measurements on some other flashlights to compare.
Used ICR18650-26C battery
  SF36 VG10S VG10 S2+ 6*7135
Moon 0,03A 0,01A 0,01A
Low 0,16A 0,15A 0,09A 0,18A
Med 0,98A 0,93A 0,77A 0,92A
High 3,20A 3,10A 2,51A 2,13A
"With the first link, the chain is forged. The first speech censured...the first thought forbidden...the first freedom denied – chains us all, irrevocably."
My reviews:
Sofirn SF36 /// Thorfire VG10S /// Sofirn C8F /// Zanflare F1
Edited by: XXX-Man on 07/09/2017 - 14:16
Splott-Light
Splott-Light's picture
Last seen: 4 days 27 min ago
XXX-Man,
Thanks for the time and effort you made in sharing this with us.
Just ordered some Sofirn AA Lights (same as Thorfire), so looking forward to more reviews and views like this.
Cheers,
Splott-Light Smile
Ouchyfoot to a New Member: Welcome CJ. Now you have to learn about buying an inexpensive flashlight and modifying it until it either blows up, or starts small fires on the moon…………
Hugh Johnson:
I, too, once lived a tragic and empty life. Then I found [portable] light.
You forgot to mention clothes. I sold most of my clothes to fund my light collection. This is actually fine, since I only go out after dark, and most people can’t see me.
Finally, I got my priorities straight.
khas
Last seen: 13 hours 53 min ago
Thank you for a great review, nice looking flashlight, I think the rings in the beam comes from the XP-L2 emitter.
Thanks for sharing Beer
XXX-Man
XXX-Man's picture
Thank you for nice words.
This is my first review so I try to do my best.
I believe this is the way review is supposed to be, just text and some personal opinion never matered to me when looking at reviews.
Hope I get time to post more like this.
My reviews:
AgentSteel
AgentSteel's picture
Last seen: 6 hours 36 min ago
Great review Thumbs Up
I am also testing this light for a review, and I can confirm the greenish outer ring on the beam. But it is only very noticeable indoors and on clear walls. Not really disturbing when using the light outdoors.
Quidquid latine dictum sit, altum sonatur
CRX
CRX's picture
Last seen: 10 min 10 sec ago
Good teardown Beer
Wildcat
Last seen: 19 hours 19 min ago
Driver is primitive direct drive with PWM and without stabilisation Sad
hank
hank's picture
Last seen: 7 hours 42 min ago
Do you mean the light gets dimmer as the battery voltage goes down?
The Miller
The Miller's picture
Last seen: 1 year 1 month ago
nice review!
thanks
I have to do the exact same light, but you done an excellent job, maybe I should just send mine back Smile
XXX-Man
XXX-Man's picture
Added current measurements, but I’m sure they are not completely accurate.
Thank you for nice words, you just made me do another review (VG10S), will post it soon.
My reviews:
Sofirn
Sofirn's picture
Last seen: 12 hours 46 min ago
SF36: Non constant Current output
Beachlogger
Last seen: 2 months 5 days ago
Great review, does the battery tube interchange between the sofirn and the thorefire?
Wildcat
Exactly. No constant output at all. FET, PWM 21 kHz.
Wildcat
Replace my sf36 then, I want constant output when voltage > 3.7 V Wink
You SP-series have stabilisation when voltage > 3.7V, but SF-series (SF36, SF31)- NO.
XXX-Man
XXX-Man's picture
No, it doesn’t.
It’s very different design on the part conecting the head, you can see in my VG10S review.
http://budgetlightforum.com/node/55233
My reviews:
Serp
Serp's picture
Last seen: 2 weeks 2 days ago
Good review. _8502 sot23-6 on board Smile
You can safely use non-protected batteries. Protection already exists in the driver._
XXX-Man
XXX-Man's picture
That’s good to know.
My reviews:
Serp
Serp's picture
Serp wrote:
Good review. 8502 sot23-6 on board Smile You can safely use non-protected batteries. Protection already exists in the driver.
I got mine and checked it.
Unfortunately this does not work.
The flashlight starts flashing when the voltage drops below 2.7V
edit: power off after 2 min
Some of my photos in the album http://forum.fonarevka.ru/album.php?albumid=1258
AgentSteel
I need to double-check with my SF36 but I think the light turned off when testing with an unprotected battery.
When the LVP starts blinking you should change battery ASAP anyway.
EDIT
So I did :
at 2.78V the LVP blinking started, then after ~1min the light turned off.
But if I turn it on again, it will do another blinking cycle, then turn off after ~1min again. Etc, etc.
Maybe you got a faulty driver.
XXX-Man
XXX-Man's picture
About 2.7 is turn off for mine too.
Can’t remember exact number but that’s close enough.
My reviews:
hank
hank's picture
Has anyone compared the drivers for sale with the drivers in the flashlights?
I’d like to know which ones are used. They have three drivers for sale, identified with a flashlight model number:
https://www.aliexpress.com/wholesale?catId=0&initiative_id=SB_2017072812...
(C8S, VG15/SF31, and C34)
I can’t tell which have low voltage protection, or whether any of those are constant current drivers (I don’t own any of those flashlights)
Serp
Serp's picture
On the Fonarevka.ru, they tell me that it does not turn off immediately. It is necessary to wait some time, after it starts to flash. But I can check it only on Monday.
At mine – usual direct drive. Without an inductor. From the laboratory power supply at 4.2V, the current on the LED is 4.6A (Hi mode)
Serp
Serp's picture
and power off after 2 min Thumbs Up
XXX-Man
XXX-Man's picture
What I see is none of that drivers from Aliexpress is not in SF36.
My reviews:
DB Custom
DB Custom's picture
Last seen: 1 hour 19 min ago
Wondering if a clamp meter on a loop of negative lead from the mcpcb would clearly show the emitter amperage as a cell loses power? That would easily clear up direct drive or regulated questions.
XXX measured 3.2A at the tail, which is not direct drive even if only limited by the R091 sense resistor. Higher amps would be easily obtained through a change in the resistor.
Tracy confirmed, above, that this is not intended to be a constant current driver. So it’s all probably a moot point… just wondering why we get a 3.20A reading on a cell and a 4.6A reading from a power supply?
I think I actually like the SF36 better than the VG10 series due to the knurling… Wink
XXX-Man
XXX-Man's picture
Soon I will build my power supply with DPH3205 so I can provide info on current with it.
My reviews:
DB Custom
DB Custom's picture
I recently acquired a power supply, for a specific purpose. After this purpose I will be able to use this lab style power supply on my bench, but since I know virtually nothing about these I find myself at a loss as to why I’d use it over just using a cell like I’ve always done in the past. This is why I ask. To what point is the power supply used? The readings one gets are not valid as we use a flashlight with cells, which sag and lose power.
I needed a supply for an 18V emitter that would use up to 1.2A current. So I chose a 30V 5A unit. It’s working great for this project, so far, remains to be seen what I do with it afterwards…. a lot to learn still. Smile
XXX-Man
XXX-Man's picture
You are correct. Cells drop voltage at high current fast.
My reviews:
DB Custom
DB Custom's picture
Especially at an 8.5C discharge rate. Big Smile
XXX-Man
XXX-Man's picture
Well I don’t have light like that…
My reviews:
