Actualy, some of us use those short bursts of power as they should be used, 10-20 secs tops for a quick observation, and thats okay
I personaly do it quite often when hunting : with either my mounted torch, or mu hand one, or with the powerful offhand torch when i am searching for the animal body or a track or smth
The thing that is not okay is the flashlight( the driver, yes) sability on a long term base…and my personal experience says its not okay, especialy talking about those fansy boost drivers
A heavy modded X6 also drops at about 1200lm from 4k in a minute or something, but my personal one is already 1.5 years old, i use it quite often yet its stable as a rock.
Of course it’s going to step down. I’m just worried the light is going to be stoopid bright when switched on… then after 10 seconds or so it steps down to moonlight mode… forever… and it’s not getting brighter anymore… $220 is really nice, but at the same time this price on day one for such a caliber of a light just seems too low, and worries me as well.
(And two days later I get a reply from customer service: “we can offer you a $5,- refund.” :person_facepalming: )
There is no way that this light will step down under 5000 lumens after it reach 50 degrees Celsius. Actually it will all depending on outside temperatures. With body mass of 1kg I expect that it will run for a 60 seconds from 30000 to 25000 lumens and then it will step down to maintain temperature under 50C….
Whell that is just my opinion and, I hope that I will get chance to get one of the first production samples like I did with DT70 and get the true readings of lumens and temperature.
This looks more like a custom product to show off lumens than one designed for real use. I’d rather have 3 or 4 emitters in much larger reflector for double the throw and running at high power through the runtime. What’s the point of having a light that can only run continuously at 15% of its full potential?
Why couldn’t they invest the R&D money into making a proper active cooking system instead of cramming as many emitters as possible in a flashlight? For me this is more like a fetish product for pleasing people with fake numbers, maybe winning the lumens race is more important than making a practical product, I don’t know.
“Active cooking system”. Lol. I’m not sure if that’s a typo, but it’s probably accurate!
I don’t have a problem with an active cooling system in a high-powered light. But it has to be small and light enough that the light is still easily held with 1 hand. And preferably will fit into a jacket pocket, though I get that throwers probably won’t.
The largest (and brightest) light I have is an old hand-held spotlight (150 watts, iirc, maybe 200?). Powered by a SLA battery, it is large and heavy and only runs for about 5-10 minutes. It is well-balanced, so easily held in 1 hand, but very impractical. A fun toy, but that’s about it. Heat isn’t an issue, because it is incandescent and the bulb is out in front of a large reflector.
LEDs and electronics make such a light way more difficult to design, in order to get rid of all that heat where it’s not wanted.
Maybe the solution to making super-bright lights is to go back to incandescent bulbs? They’re inefficient, but heat is easily dealt with by placing it far away from the battery. Plus, there’s minimal electronics needed. Okay, there’s the issue of run-time, which will suck.
There are so many kinds of flashlights. Lots of very different kinds of flashlights. Very small lights. Moderately small lights. Medium size lights. Big lights. Very big lights. Some people like lights of different size and different types. Some other people only like certain types of lights.
I like to post to say what I like about the lights that I like. There are several types of lights that are not interesting to me, so I do not post in those topic threads, to say why I think those lights are useless to me. I just simply let those nice people enjoy posting what they like about those types of lights. No posts from me telling them why that light is useless for me.
Maybe, one day, people who don’t like the lights that I like will return the favor.
The heatsink with fins inside the body is pretty useless, if you ever saw the passive heatsinks that have to cool only 100W you know what I mean
they are huge, this heatsink in there is just a joke, a massive aluminum block would be better
@richbuff, we know manufactures read BLF, so also critical posts can have influence.
With lack of info makes us speculate awaiting real user experience.
I really hope the people that have already bought this are going to e dry happy with it for sure.
But point taken, will wait till more is known
I’m a little bit more optimistic. Two things I’d like to note. First is that the passive heat sink examples you have shown is probably for steady state operation of the 100W CPU (?), meaning such large passive heat sinks are required for a maximum temperature for normal CPU operation.
The DX80’s passive heat sinks are not meant for steady state operation of 32000 lumens, but (1) to extend the high output for a longer period of time compared to when it doesn’t have this structure, or (2) for a higher steady state temperature of around 5000 lumens.
Secondly, looking at the first picture you’ve posted, there is thermal resistance between the heat source and the heat sinks, in the form of these slender copper connectors. I think this is a fairly weak link for efficient heat sinking. The heat sink of the DX80 is (hopefully) more efficiently attached to the heat source: led board > shelf > heat sink. The surface is also fairly large.
So at this point I’m a bit more optimistic. :partying_face:
But how about the following idea? So you have these vent holes on the side of the light. What if you attach a small compressor on one side for forced ventilation (active cooling)? Obviously this is not going to work outside, but is merely for experimental purpose. I mean this thing is going to cool like crazy or what? I’m interested how this is going to influence performance and step down time of the light… :smiling_imp:
Maybe it will be okay if tightly hand-held, so the heat has somewhere to go. Probably not at 32,000 lumens, but perhaps at 5,000. I find that it’s tail-standing that really heats up a light, even at moderate output levels. (Nowhere for the heat to go, after it has warmed up the metal of the light.)
It sounds like Imalent and Acebeam are probably having a bit of an arms race, with the DX80 and X80.
Between the two, the X80 looks like it could make a useful “mule” type light at 1.1 cd / lm, and the DX80 has more of a typical EDC beam at 5.1 cd / lm.
Of course, neither one is small enough for EDC, but they could be useful for other purposes.
I can’t really complain about having a turbo mode which can only run for a short time, with a stable output level only a fraction of the maximum. Pretty much every single-cell triple or quad falls into that category… and they still manage to be fairly practical items.
The (D)X80 seems less practical (more specialized) due to size and price, but its hotrod nature doesn’t automatically disqualify it from being worthwhile.
I centainly affirm this light have NO active cooling system otherwise imalent would inform and repeat in every ad……
So, I need which Imalent proves that light can be useful and can do more than Thorfire S70 in continuos output….
About the cooling system yet, I dont look closer to this DX80 but if this thing dont have holes in the tail or near that, those holes in the head almost do nothing and even in the tail have holes the convection flux will only works effective if it tailstands or the head stay in higher level (non practical use light)
Saying that, for me the lights with active cooling should be sold long ago!
Its very funny you tell this about race and cars because almost all “huge” “engines preparation” with turbo charger claims unreal horsepowers values but you cannot use that more than 6~10s otherwise the engine blow :person_facepalming:
We cannot admit some products with the motto “you have it, but not use it!” :confounded:
Hmm, my “little” 3800lm DN70 will run about 90 seconds or so on turbo before the heat warning begins to flash. It will cycle down to 1800 and continue for quite a few more minutes at that level. Or, I can run it at 2500lm for several minutes (maybe four or five?) Before it cycles down. In real life, it seems a long time to have it on :). On my hikes, I often run it in 2500 for few minutes to get my bearings, then cycle down to 300, which, due to the excellent beam pattern is plenty for normal hiking.
I guess one gets used to the personality of the light and the way you use it over time adjusts. I never think about it much any more, the manipulation of it to fulfill my needs is just natural, and not hindered or dictated by the step down. Love it!
