It shows on the ad that with 30q cells and the xpg3 emitters, it will do 12,000 lumen. That’s about 666 lumen per emitter, which is really pushing them.
I was told that they can make double click to Turbo and triple click to Strobe. Wasted 1.5hr at post office for some returns today. I have to double check with them again.
One thing is for sure, you cannot use flat top in the new battery carrier. There will be plastic insulators on the anode (+) ends to prevent loading batteries in reserved direction. I suspect you can remove them but you will risk damaging the batteries or even light if you make a mistake for the polarity.
The cells are paralleled at the battery carrier. Put one in backwards and two cells will be shorting each other out before you can install the carrier in the light.
