ENEDED
He was already asked this and said yes, GB will be cheaper. He didn’t say it directly, but gave a wink and a nod. Lol
The light draws 120W electrical power, lets say the driver has an efficiency of 85%
102W
so we talk about roughly 100W to the LEDs
100W/18=5.56W per LED
lets look at http://pct.cree.com/dt/index.html for XP-G3 S5s with a Tj of 50°C for cold start
thats a bit over 13000 Lumens
I am interested, thanks.
should be LED lumen tho.... don't know how much drop does the glass and the optic do.
Interested, looks like the Mecarmy PT60…
So did they change what the double click does or does it still just go to strobe?
I hate strobe! :rage:
I was told that they can make double click to Turbo and triple click to Strobe. Wasted 1.5hr at post office for some returns today. I have to double check with them again.
Interested.
oh, that’s good, double click to strobe is so stupid
One thing is for sure, you cannot use flat top in the new battery carrier. There will be plastic insulators on the anode (+) ends to prevent loading batteries in reserved direction. I suspect you can remove them but you will risk damaging the batteries or even light if you make a mistake for the polarity.
ops, most high drain batteries are flat-top, they cant add reserve protection in driver?
Is it possible to use protected button top batteries? What are the limiting length and diameter?
The cells are paralleled at the battery carrier. Put one in backwards and two cells will be shorting each other out before you can install the carrier in the light.
Throw my name onto the list too please.
This, or add something else. Or just clear instructions in multiple languages and hope for the best?
Please add me to the list. If I understand it right, the cells are 2S2P and the LED's are 3 groups of 2S3P, so perfect for a FET based driver.
Interested.
i see what you did there, imagine 18*xp-l2, that would be :smiling_imp:
It’s an important safety feature and should be there.
If someone (you, your wife or your kid) puts a cell in the carrier backwards, two cells short with a strong possibility of venting or bursting into flames right in front of their face. Drop the thing in the wrong place and your house catches on fire.
It’s much better to use the correct batteries or add solder tabs.
