The cells are paralleled at the battery carrier. Put one in backwards and two cells will be shorting each other out before you can install the carrier in the light.
Itâs an important safety feature and should be there.
If someone (you, your wife or your kid) puts a cell in the carrier backwards, two cells short with a strong possibility of venting or bursting into flames right in front of their face. Drop the thing in the wrong place and your house catches on fire.
Itâs much better to use the correct batteries or add solder tabs.
Latest specs from Bangood, due in stock August 25.
It could use one more mode, the run times make it look like its going to thermally throttle at the third level pretty quickly. The mode levels seem weird so maybe these are still preproduction numbers.
Product name: Astrolux MF-01 18x XP-G3/Nichia 219C 12000LM LED Flashlight
Brand: Astrolux
Model: MF-01
Emitter Type: XP-G3/Nichia 219C
Light temperature: 6000-7000K,5000K
Light color: Cool white,Neutral white
Material: Aerospace grade aluminium alloy
Total Emitters: 18x
Mode: Low,Mid,Mid1,High,Turbo + Strobe,SOS,Location Beacon
Lumens: 100LM,600LM,1550LM,5100LM,12000LM (Sumsang Q30 XP-G3)
70LM,700LM,1100LM,6800LM,11526LM (Sumsang Q30 Nichia 219C)
Runtime: 500h,14h,4.7h,4h,3.5h (Sumsung Q30)
Battery Configurations: 2 x 18650/4 x 18650 battery (not included)
Voltage Input: 5.5V-9V
Switch Type: Clicky
Switch Location: Body side of the flashlight
Peak Beam Intensity: 53960cd
Impact Resistant 1.5m
Max Output: 12000Lumens (XP-G3)(tested with 4x18650)
Range: 450meters (max)
Lens: Toughened ultra-clear mineral glass with anti-reflective coating
Waterproof: IPX-7 waterproof
Color: Black
Weight: 550g (without battery)
Size: 125mm x 72mm x 52mm (length x head x body diameter)
