ENEDED
Throw my name onto the list too please.
This, or add something else. Or just clear instructions in multiple languages and hope for the best?
Please add me to the list. If I understand it right, the cells are 2S2P and the LED's are 3 groups of 2S3P, so perfect for a FET based driver.
Interested.
i see what you did there, imagine 18*xp-l2, that would be :smiling_imp:
It’s an important safety feature and should be there.
If someone (you, your wife or your kid) puts a cell in the carrier backwards, two cells short with a strong possibility of venting or bursting into flames right in front of their face. Drop the thing in the wrong place and your house catches on fire.
It’s much better to use the correct batteries or add solder tabs.
You’re going to need some good oven mitts for that.
Maybe you are not familiar with my work. Been there, done that.
Slightly familiar, do you think a Harley Quinn board is going to fit in there?
Narsil and ramping would be awesome in this light.
do a Narsil board for this light
maybe with some of those new 12V CC chips for the middle modes
12V CC chips? I've been off the grid for a while...
Hi,
Interested.
Depending of the GBprice.
Interested depending of the price… :money_mouth_face:
Interested as well…
Went right from “interested” to obsessed after the PM. Thank you!
Interested
Interested in price please. :sunglasses:
Latest specs from Bangood, due in stock August 25.
It could use one more mode, the run times make it look like its going to thermally throttle at the third level pretty quickly. The mode levels seem weird so maybe these are still preproduction numbers.
Product name: Astrolux MF-01 18x XP-G3/Nichia 219C 12000LM LED Flashlight
Brand: Astrolux
Model: MF-01
Emitter Type: XP-G3/Nichia 219C
Light temperature: 6000-7000K,5000K
Light color: Cool white,Neutral white
Material: Aerospace grade aluminium alloy
Total Emitters: 18x
Mode: Low,Mid,Mid1,High,Turbo + Strobe,SOS,Location Beacon
Lumens: 100LM,600LM,1550LM,5100LM,12000LM (Sumsang Q30 XP-G3)
70LM,700LM,1100LM,6800LM,11526LM (Sumsang Q30 Nichia 219C)
Runtime: 500h,14h,4.7h,4h,3.5h (Sumsung Q30)
Battery Configurations: 2 x 18650/4 x 18650 battery (not included)
Voltage Input: 5.5V-9V
Switch Type: Clicky
Switch Location: Body side of the flashlight
Peak Beam Intensity: 53960cd
Impact Resistant 1.5m
Max Output: 12000Lumens (XP-G3)(tested with 4x18650)
Range: 450meters (max)
Lens: Toughened ultra-clear mineral glass with anti-reflective coating
Waterproof: IPX-7 waterproof
Color: Black
Weight: 550g (without battery)
Size: 125mm x 72mm x 52mm (length x head x body diameter)
Alright, I am jumping on this ship as well. INTERESTED in price please!
Thank you!
