I cant measure the real output, but I estimate about 10000 lumens
The light steps down after 2 minutes when cold, when really hot its about 1 minute.
But when the light steps down first time from being cold its on the edge to be held comfortably on the tube and way too hot to touch the head,
you would not do another turbo unless wearing gloves.
I tested the light in ice water and it seems it the timed stepdown is always there just shorter when the light is hot.
So if I understand this right, the cells are 2S2P and the LED's are 3 groups of 2S3P. Therefore, you can run the 3 groups in parallel and have a fully 2S LED setup with 2S cells, therefore a FET based driver can be used. I think that's right??
Yea, awesome. Just wonder if the std SRK size boards will fit. Might not have clearance for piggybacking in there? From your pics, looks pretty tight. Not sure if a SRK style driver would fit or be compatible as-is.
For $20 it would be a Q8 killer . I wouldn't bury the Q8... yet. Without knowing lumens, throw and how the UI works, hard to compare. Only 4 output levels compared to smooth ramping plus multi mode sets, etc... I can also still pocket a Q8 but with the wide head on this, I don't think I could.
depends how many want one
Oshpark sells always multiples of 3 boards
so if only one would want one thats 17.55$ for 3 boards
Prices:
17-22mm
Narsil v1.4
13.5$ Attiny85 with temperature calibration
14$ temperature calibrated, 1S LVP calibrated to any value you want
NarsilM Attiny85
12.5$ flashed no settings,
13.5$ with temp calibration and max temperature preset,
14$ with calibrated 1S or 2S LVP / temp calibration and max temperature preset, this version has no indicator LED
loose spring adds 0.3$
47.6mm add 5$ if 3 boards come together
LDO 1.2$ 21mm and bigger only
Bistro or Narsil customized modespacing adds 1-2$ depending how many groups you want changed
or you suply a hex add 0.5$
SRK Size with more than 8 AMC7135 Bank add 1$ for all 16 AMCs
so NarsilM without calibration
12.5$
LDO 1.2$
copper alloy spring 0.3$
5$ for bigger board if 3 drivers gets ordered
2$ shipping
1$ 16 AMCs
Good flashlight, but… you know, after this story with S42’s short tube and ugly USB cover too hard to trust them…
When I think about thear QC, I am understand that this QC - is only checking if it’s posible to turn on a flashlight.
So, thank you, Asrolux, but NO, until full reviews and specs.
