By then I may have finished the automated sending of PMs, not just generating the PM lists. I’m working with SB now on testing.
Is it to late to get on the list for 1.If not out me down for 1 please
Wow! This forum is getting better all the time! And it’s all because of members taking up the mantle and making things happen! :+1:
I’m in for 1 ,please.
Welcome to BLF!
Will update list later!
Yeah awesome!
I am interested, thanks!
I’d be keen for one of these too, please
Hello!
I would also like to be added to the list please!
The light looks very good!
Thank you very much!
Yes will update list soon
And Fritz is finalizing the driver, hope it can be presented soon for it is a thing of beauty!
Its structure is nothing special
That may be true. But, why did you feel the need to make that comment here? Do you wish to elaborate on your statement?
Bạn có thích đèn pin không? Bạn sở hữu bao nhiêu? :innocent:
anyone know how many lumens this flashlight will pump out, or how hard it is going to be driven?
Wrong topic?
Or what do you mean?
The driver structure is special, The double tube structure is special.
The tail switch construction is special
Yeah the optics are if the shelf, you mean that?
We have to test actual lumens, let’s keep it at 2000-2500
ah yes thanks so it should read: new mode groups: low 12% 7135 - low med 25% 7135 - med 50% 7135 - high 100% 7135 - turbo DD low 12% 7135 - med 50% 7135 - high 100% 7135 - turbo DD low 12% 7135 - low med 25% 7135 - med 50% 7135 - high 100% 7135 SAFE no turbo option low 12% 7135 - med 50% 7135 - high 100% 7135 - SAFE no turbo option If I recall it correctly, there are several multi mode options, but a lot got the FET kicking in. I think all actually, nice with a big light and 1 7135 chip. …
Another small update, the driver is basically done Here are the pictures from oshpark.
Board Top
Board Bottom
Top Layer
Bottom Layer
At this point I’d like to thank DEL who patiently answered all my stupid questions and consistently gave advice on the schematic as well as the layout of the board
hanoilighting208:Its structure is nothing special
Wrong topic?
Yeah the optics are if the shelf, you mean that?We have to test actual lumens, let’s keep it at 2000-2500
Nothing Special?
What Polka dot colors does Fritz need to add to the PVD formula?
That was all I needed to read.
OK ……. The Miller please slip me into the waiting line for 3 of these.
fritz15, could you tell dimension of driver d and h ?
Board Top
Board Bottom
Top Layer
Bottom Layer
Nice! Thanks for showing this! Are these boards shared on OSH Park, or you keeping them private?
Great job and thanks for sharing!
I don’t see why not. But unfortunately, the driver is made specifically for the FW3A and won’t fit for other lights due to the second tube. I can add the link to oshpark when the driver version is final
