That is possible, I see no reason why that could not happen but all of that will have to be figured out much closer to when the GT is ready for shipment.
Can you post a pic next to a K60 or K70? We need beamshots please!!!
Nice! looking forward to the reviews.
Sorry Alex, l dont have either mentioned lights. The biggest light I have that has been purchased would be the original Defiant Super Thrower which is not in this league.
On a personal note I’d prefer the longer tube not that I have seen the light with it. It should balance the weight out a little better.
As far as adding weight I dont think it would add a great deal to it.
That is just amazing!
I can imagine that grin on your face and your wife’s reaction :sunglasses:
Almost 2 kg’s! This is one serious light
Cant wait to see more details and beamshots ofcourse!
Looks Awesome! Can you take full outer measurements and post in OP? I can't find them in the GT thread OP either - no outer head diameter #.
Thanks!!
Looking forward to seeing this tested with the long tube and two carriers, like the original design.
Oooooh! So close, I can almost touch it! :partying_face:
Hey Steve, can you measure the diameter of the battery tube at the threads? Wondering if the SD75 tube might fit??
Any requests I’ll try and do after work today. Approximately 9 hours time. :weary:
Edit. It would also be nice if anyone had suggestions on a carry bag for this light. Even for transport purposes to stop it getting damaged.
How about this one? Not sure if it would fit though…
Would something like this be fitting?
134mm head OD
85mm fin OD at button
56mm battery tube
62mm battery cap OD
~315mm total length with long battery tube (ruler only goes to 305mm, guessing on the last 10)
These caps might work for a lens cap, if heated up and pressed on. 133mm
Interesting idea, that could work indeed.
Theres some nice ideas. The pipe cap looks good and ccc bag if it had a shoulder strap looks like a possibility.
at least the head is not as big as “millions candelas” lamps that runs H3 12v 50w bulb we used to “love”, i still have those.
There was once a “BLF lanyard” by Manafont, perhaps now there should be a “BLF shoulder strap”.
or custom paracord strap…
Yes, this light is perfect for a shoulder strap. I put my S70 strap on it and it works fantastic! Review coming tomorrow. Leaving to take some beamshots in a little bit hopefully……if I can put off the important work I should be doing right now……
