This was the last one I bought. There are half a dozen more, but they are all the same light
Very cool mod … I just purchased a gel sheet. I love my CL25R.
Many thanks for posting.
The filter will warm up the Fenix too. Looks even nicer than the clone if you like a warm light while camping.
Fenix on the left. Both with filters
Very nice … warm tints for camping area and cooking lighting is a must IMHO.
Nice job and thanks for the heads up.
Don’t think you are going to fit it around the CL30R, unless it can be heated up to form around the curves.
CL30R is great just the way it is … great neutral tint.
I have a clone of the CL25R latern and it came with a 3x AAA holder which is around 20mm wide.
Also there is a sleeve for the 18650 battery to make it fit.
So I was thinking it should be possible to use a 20700 battery in the latern, does it fit?
I don’t think the 20700 would fit the clones I have. Did you try an 18650? My clone CL25R tubes are 19mm in diameter.
Thanks, yes a 18650 fits without a problem.
I’ll measure the tube later this evening.
Thanks!
I must have another version then
Length is 73mm so I think a 20700 cell should fit. I ordered one and see if it fits.
I’ll be darn. Do you have the link where you bought it? I just measured a real Fenix CL25R and it’s 19mm also. Your’s looks like another type of clone
I bought it here
http://s.aliexpress.com/byMnQJzu
Your’s looks more like the real Fenix than the other clones do. Same dimensions too. My clones are a little larger than the Fenix
Robert you’re my savior, for years i tried to find a good warm tint !!! my filter is already ordered for my Rayovac indestructible 3D lantern but i took the full orange one (3200k) :sunglasses: i’ll post an update soon
My clone claims to take a 22650 and provides a sleeve to fit an 18650.
That is right, 22650, NOT 26650.
Not sure who makes a quality 22650 but I can’t find ’em.
I have a CL25R for home but wanted something for the toilet at work during a power failure so bought the clone. Not quite as nice a light but more than enough for emergency lighting in the loo.
I would try the new Samsung INR21700-48G
I know the thread is old, but the Zanflare T1 has a warm tint.
Freeme’s GB:
Ended (but often sold out)
I cut the gel wrap with a paper cutter in a strip to 2 5/16” wide, and scotch taped it to the clone lantern.
How exactly did you do that? I can’t see any signs of manual changes beside the color
