The_Miller
(The Miller)
August 4, 2017, 11:16am
915
Wrong topic?
Or what do you mean?
The driver structure is special, The double tube structure is special.
The tail switch construction is special
Yeah the optics are if the shelf, you mean that?
We have to test actual lumens, let’s keep it at 2000-2500
fritz15
(fritz15)
August 4, 2017, 4:31pm
917
Another small update, the driver is basically done Here are the pictures from oshpark.
Board Top
Board Bottom
Top Layer
Bottom Layer
At this point I’d like to thank DEL who patiently answered all my stupid questions and consistently gave advice on the schematic as well as the layout of the board
Tjohn
(Tjohn)
August 4, 2017, 4:45pm
918
Wrong topic?
Nothing Special?
What Polka dot colors does Fritz need to add to the PVD formula?
That was all I needed to read.
OK ……. The Miller please slip me into the waiting line for 3 of these.
AEDe
(AEDe)
August 4, 2017, 4:55pm
919
fritz15, could you tell dimension of driver d and h ?
DavidEF
(DavidEF)
August 4, 2017, 5:04pm
920
fritz15:
Board Top
Board Bottom
Top Layer
Bottom Layer
Nice! Thanks for showing this! Are these boards shared on OSH Park, or you keeping them private?
leroycp
(leroycp)
August 4, 2017, 5:56pm
921
Great job and thanks for sharing!
fritz15
(fritz15)
August 4, 2017, 6:38pm
922
I don’t see why not. But unfortunately, the driver is made specifically for the FW3A and won’t fit for other lights due to the second tube. I can add the link to oshpark when the driver version is final
The_Miller
(The Miller)
August 4, 2017, 10:19pm
923
Thanks for sharing Fritz!
I so DIG this pic:
Just dang beautiful!
Sweet
Gonna edit the title and OP later for the unveiling of a new BLF special driver PCB certainly deserves that!
DavidEF
(DavidEF)
August 4, 2017, 11:17pm
924
Yeah, it won’t fit any lights that aren’t made for it. But, if it’s available, somebody can make another light to fit it if they want to later. Also, if somebody had a driver fail for any reason (not covered under warranty :smiling_imp: ) they could build a new driver themselves.
Looks nice.
Add me to the list for 1 please
joechina
(joechina)
August 5, 2017, 12:28am
926
ToyKeeper:
This should be fairly similar to the D4, except:
Tail switch instead of side switch. (both momentary electronic switches)
3 emitters instead of 4.
FET+7+1 driver instead of FET+1 (so, more efficient and higher regulated modes).
Narsil UI instead of Ramping IOS UI.
Different body style.
Extra pin wired up for aftermarket light-sense hacks.
At a guess, probably ~140 lm on the “1” channel, ~1000 lm on the “7+1” channels, and ~3000 lm on the FET channel. With smooth ramping from moon all the way to maximum. Or discrete levels if you prefer.
Anything up to 1000 lumens should be reasonably well-regulated.
I’m assuming I should (or someone should) probably put in some proper thermal regulation before the FW3A is released, but that probably won’t be too hard.
Putting in a blink at channel boundaries shouldn’t be hard either, but it depends on if that feature is desired.
I would also love the default memory value for one channel. I don’t know if this works with the double tube.
The_Miller
(The Miller)
August 5, 2017, 8:02am
927
The double tube is to make the switch work, does not affect the UI in any other way then making sure it can work
ifratos
(ifratos)
August 5, 2017, 8:24am
928
Thanks! I forgot to tell but I assume that you know :
I am John(Ion in native) and I am flashoholic.
joechina
(joechina)
August 5, 2017, 9:09am
929
Damn, I checked the size of my SK68.
FW3A and SK68 have the same size!
Max. outer diameter and length
That’s compact for a 18650
In for two pcs. Thank you
joechina
(joechina)
August 5, 2017, 10:18am
931
Thanks The Miller!
Could you add in the OP where the size is mentioned: “This is as small as a SK68” ?
Many know how pocketable a SK68 is and an now the FW3A with the power of a 18650
Joey_Adams
(Joey Adams)
August 5, 2017, 2:39pm
933
EVERYONE REPEAT IN UNISON:
Welcome Ifratos, you’re among friends here!
By the way: I can quit anytime I want………I just have not “wanted ” to yet. I will quit after just one more……
weklund
(weklund)
August 5, 2017, 2:50pm
934
Please put me down for 2 of these beauties … Many Thanks.
