If you asked for a preferred flashlight in this months, …. Nitecore SRT9 (arrived recently but is impressive )
The best combination of Nitecore Die Cast flashlight + magnetic Ring + rear switch. (plus red, green, UV, strobe,….)
2x18650 with 1 led XHP50 for 2150 lumens.
power indicator, great clip design,….
best matchbox recargeable flashlight?, yes, there are no doubt.
Why¿?
The better interface of all; direct acces to lowest mode, direct access to Turbo, direct access las used mode, lock out option, battery level indication…. the better interface with 2 switch.
Battery of 500 mA
In the XP-G2 version, Turbo of 360 lumens. Lowest of 1 lumen.
I have tried, other like Manker, MecArmy SGN3, SGN5…. no competence for this. Nitecore TIP is the best in this format. 2017 version is nicest, but I prefer this interface.
Please!, if you want the DN70, you need batteries like this: the provided Imalent protected or for example some like the Liitokaala 26650 unprotected (my preferred). Be careful, the longest protected like the Klarus 26650 batteries are too long and not fit here:
