Review: Manker MC11 (EDC, Rechargeable 18650 in bundle, XP-L)
7 posts / 0 new
Budda
Budda's picture
Last seen: 21 hours 59 min ago
I received the Manker MC11 from Manker.com for the Review
The Manker MC11 is a new 1×18650 EDC light, it is powered by an included Manker 18650 2600mAh (micro USB rechargeable) that feeds a XP-L emitter, and features a mechanic switch at the tailcap and an electronic one at the head. There is also available a NW version, I got the CW one.
The Box of the MC11
The MC11 comes with an 18650 battery rechargeable via micro USB, lanyard, spare o-rings and clip.
The MC11 is a Medium-Long sized 18650 EDC light (11.8×24 cm)
The tailcap, only removable part of the light, has anodized threads so physical lockout is possible.
The tailcap hosts a mechanical switch. The switch protrudes making tailstanding impossible.
The head has an electronic switch
And hosts an XP-L Cw emitter in a OP reflector
UI
1. When the flashlight is off, half press the tail switch for momentary on, the output mode will be your last mode (Memory function, strobe included)
2. Single click the tail switch for on / off, click the side switch for mode selection
3. When the flashlight is on, long press the side switch for strobe and long press to get back to general mode
4. Engineering mode (Choose output level for moonlight mode): when the flashlight is on, quick click the side switch for 4 times to get access to engineering mode. Single click to change the output level and then click the tail switch for off to make your final choice.
Beamshots at 0.5 meters from the wall
A XP-L emitter in a small OP reflector gives a very wide beam, suitable for close distances.
Output and runtime
Measured using the 18650 2600mAh battery that comes with the light
I also tested the Capacity of the 18650 cell, discharging it with my SKYRC MC3000 at 2.0A until 2.8 volts are reached. Unfortunately, the new SKYRC software is affected by the 10’000th bug, and now I can’t even have a complete log of the test; so I’m unable to show you the plot, but I can tell you that I measured 2515 mAh from the full charged cell.
Thermographic Test
My thoughts
The MC11 is well built and finished.
The MC11 is a on the large side of 18650 EDC lights, but that’s what happens when you have a flashlight with 2 switches.
Level spacing and regulation are fine. The MC11 has memory mode but not quick access to highest or lowest mode, things that I usually like on all my lights.
The included battery works fine, and, although doesn’t have the highest capacity, it is easily rechargeable using the micro USB cable integrated.
I would have liked to see this light with an XP-L Hi emitter, able to give the MC11 more throw.
I would like to see the MC11 come with a sheath too.
Thanks to: AntoLed for the camera help, the thermal camera and the luxmeter; Zampa for the tripod.
All my reviews, in italian and english, here: Lumenreviews.com
Trevi_lux
Trevi_lux's picture
Last seen: 52 min 57 sec ago
Thanks for the work Budda, as always a good presentation.
However this time the flashlight, I find a little boring, does not make me feel anything special. Please manker, strive a little more, the E02 and E02H are original and attractive, but this MC11 … a word, boring.
firedome
Last seen: 7 hours 3 min ago
Nice review, thanks! Thumbs Up
“We can easily forgive a child who is afraid of the dark; the real tragedy of life is when men are afraid of the light.
-Plato
Budda
Budda's picture
Manker has gotten us used to very innovative and special lights.
The MC11 is just a more conventional light.
djozz
djozz's picture
Last seen: 9 min 55 sec ago
Thanks for the review Budda. I agree that this light has little special features (although I like the user-settable moon level) and some are missing (direct access to low and high). We are definately spoiled nowadays with ever better user interfaces around!
One detail from your review: on turbo you compare the specified output (1300 lumen) to your measured output (1294 lumen), but, following the ANSI guideline, should you not use the output at 30 seconds (1220 lumen) instead of the output at start-up?
link to djozz tests
“I used to think that top environmental problems were biodiversity loss, ecosystem collapse and climate change. I thought that thirty years of good science could address these problems. I was wrong. The top environmental problems are selfishness, greed and apathy, and to deal with these we need a cultural and spiritual transformation. And we scientists don’t know how to do that.”   (Gus Speth)
mrheosuper
Last seen: 5 hours 6 min ago
lack of tail standing is a no to me
and the battery that goes with the light has a poor capacity, i would like to see 3400mah or something else, at least above 3000mah
Forgot my pen
Budda
Budda's picture
I always measure the output at Time “zero” (actually i need a few second to turn the light on and move to the luxmeter display which is a couple meters away). That’s how I do it.
From my plots magnifications, that I tent to always include in my reveiws, it is easy to get an Idea of the 30” output. Sometimes the output even increases during the first 30” and I always report the 0 time.
I can’t call my data “ANSI” even if I measured them at 30” because every test happens at a different temperature, and I don’t use an integrating sphere.
