Emisar D4 Mods
121 posts / 0 new
CRX
CRX's picture
Last seen: 32 min 14 sec ago
Emisar D4 Mods
Received this wee fella today, love it! Nichia 219C flavour.
There is not much to modify on this light but I thought it needed a magnetic tail & tritium vial, lined the battery tubes for better fit, also a GITD recessed switch & bezel, carbon fibre wrap on the tail and some o-rings in the body grooves for grip.
It's had a few revisions so far...
GITD rubber switch surround.
Recessed GITD black switch.
PK Paladin clip.
USB Rechargeable using 18650 tube.
LED Lighted metal switch.
Carbon fibre & acrylic lighted switch ring.Emisar D4 Quad Nichia 219C 5000K - v2 - 18350 - EL S Sw - 3600lm....
Making a magnetic tail.
After some measurements I decided it was workable although I had to destroy the PCB in the process as it is glued in place but that doesn't matter now Wink
I did try heating the tail cap and pulling on the spring but that snapped off at the solder joint so I chose to drill some holes in it until it yielded. I could have applied more heat but didn't want to risk altering the colour.
One good thing about installing the copper plate is that I was able to adjust where the tail cap lettering aligns, if that sort of thing bothers you Big Smile
This also allows me to know at a glance whether the light is locked out or not.
Some measurements:
Spring compressed & PCB combined - 2.2mm
PCB alone - 1.07mm
Internal tail diameter - 22.24mm
External tail threads - 23.2mm
End cap thickness - 2.54mm
I had originally hoped to just fit a 22mm magnet in there with a thin copper plate but a 22mm x 2mm magnet is too thick, all I had, so used instead an N52 18mm Neodymium magnet with a pressed copper disc and some 1mm copper wire as I did not want to shorten the tubes either.
A 22mm x 1mm N52 magnet might do but seem very hard to find.
18350 Rechargeable Version.
I made a charging module and changed the magnetic tail.
The charger is made from copper sheet, tiny ME4056 board and brass contacts. Space was lacking so I drilled holes for the new 6mm x 2mm neo magnets and made a new copper contact plate.
The internal top of the battery tube was stripped of anodising using drain cleaner for electrical contact with a slot cut in to just above the o-ring for the USB port.
Another switch revision, I used a piece of 12mm x 1mm carbon fibre tube, 10mm x 1mm clear acrylic tube, 0.5mm clear silicone sheet and 0.5mm black kydex for a green lighted glow circle around the switch button and DIY glow disc under the optic.Emisar D4 Quad Nichia 219C 5000K - v2 - 18350 - EL S Sw - 3600lm....
DIY Glow Disc
Feel free to post your own D4 mods here too Thumbs Up
Edited by: CRX on 09/01/2018 - 11:37
Slayer1
Slayer1's picture
Last seen: 23 min 29 sec ago
Sweet!!!
Sledgestone
Last seen: 4 months 6 hours ago
You sure don’t waste any time CRX! Thumbs Up
ven
ven's picture
Last seen: 4 hours 52 min ago
WOW, no flies on you Steve…………..looks fantastic and even more useful with a touch of your magic.
CRX
CRX's picture
Thanks Beer
lumenzilla
lumenzilla's picture
Last seen: 2 days 7 hours ago
Awesome hacks Thumbs Up
Agro
Last seen: 3 hours 55 min ago
Making the contact springless should slightly reduce resistance making the light another bit brighter, right?
Anyway, the mod is much harder than I expected.
CRX
CRX's picture
Maybe marginally. I had a closer look at the PCB copper, it is about 0.2mm thick Thumbs Up
Coupled with the HQ spring when compressed is very low resistance although not as clean as my 0.3mm one piece copper.
What did bother me was how easily the spring detached, almost like a cold solder joint.
Possibly not, I like to do things the hard way Big Smile , the most difficult part was getting that contact out, left sitting in boiling water for a while would probably do it but I got no patience, then if you find a 22mm x 1mm magnet, the highest strength possible due to the thick tailcap aluminium and some 0.2mm copper sheet you wouldn’t have to press it into shape or bother with the support copper wire ring.
Also note the magnet won’t hold the 18650 version horizontal, only works with the 18350 due to the 2.54mm aluminium in between.
Another way is to file down the battery tube about 1mm and install a strong 22mm x 2mm magnet with a thin copper disc on top but filing the tube is a bit dodgy.
DB Custom
DB Custom's picture
Last seen: 2 hours 49 min ago
I took the liberty to lighten the pic up some so your work could be seen, now that I can see the carbon fiber end plate and all it’s easy to see how much you’ve brought out the D4. Nice work!
CRX
CRX's picture
Thanks mate, I guess most of my pictures look too dark to everyone else then? I’ll lighten them up some in future Thumbs Up
Edness
Edness's picture
Last seen: 4 days 22 hours ago
Love it!
You just gave me an idea. I hated my Acebeam X80 tailcap with all the unnecessary branding. I’m going to cover it up like you did with this light.
CRX
CRX's picture
Cool Thumbs Up
Gunga
Gunga's picture
Last seen: 10 hours 15 min ago
How did you do the trit like that?!
CRX
CRX's picture
I first thought about a slot which would have been better but more risky to do so I just drilled a 6mm hole right in the centre of the D4 letters for the 6mm x 1.5mm trit, backed by a 6mm x 0.5mm magnet.
After the hole was drilled & cleaned I put the 18mm magnet in the tail, stuffed blutak in to hold in place, put the 0.5mm magnet in the hole followed by the trit then filled with layers of UV glue. I do deeper sets like this in layers because the glue shrinks a bit when hardening with UV light.
Ronin42
Ronin42's picture
Last seen: 2 months 3 days ago
Bravo
(“It’s good that most people can’t remember their previous lives. Otherwise
things would be a lot more complicated than they already are.”
Ajaan Lee Dhammadharo)
leroycp
Last seen: 9 hours 48 min ago
Double bravo!!
Agro
CRX, I’m looking for ways to hang my D4 in a tent.
Slightly loose o-ring seems to be the best option so far. What size did you use and how tight was it?
CRX
CRX's picture
Another reason I like to install magnets in my lights and other stuff is because I have a couple large neos stitched into pieces of fabric to the top tent pole sleeve underside of my tent so you can just stick stuff there like lights, small USB fan, radio etc.
I also have a line of paracord running along there too for stuff with clips, but anyway the o-rings I used for a tight fit are about 18-20mm x 1mm, nitrile or other firmer material is best as silicone is too soft and will pull out of place easily but for your needs maybe a soft 22-24mm id x 2 or 3mm would do or make a thin piano wire type clip. Don’t be hanging the D4 in a tent on full power though… Wink
SubSailorVet
SubSailorVet's picture
Last seen: 1 month 1 week ago
Excellent mod sir! I love the o-rings in the body grooves for grip. I’m buying a bunch a o-rings today for my light grooves in all my lights. I bought this light and have really enjoyed showing it off to my buddies. They can’t be.ieve something so small can be so blazingly bright. Some are planning on buying their own. Thanks for the great info and ideas. Thumbs Up
Best regards,
Matthew
Agro
Could hurt the eyes; other than that, TK will come and restrict the output to some stable level.
Thx for suggestions.
Joey Adams
Last seen: 5 months 2 days ago
Oh man that looks awesome. I completely missed the carbon fiber on the bottom until Dale voodoo’d the picture. That is one awesome looking light. I wonder if the magnet would be able to hold the 18500 version horizontal?
CRX
CRX's picture
I think you would need a 22mm x 2mm magnet in there for the extra weight Thumbs Up
allcool
How did you do the “GITD material around the switch”.? it looks perfect, as does all your mods, very nice…
CRX
CRX's picture
It took a few attempts to get the right size and was tricky to do but it is just a thin strip of sticky GITD tape cut with a scalpel and pressed into the gap between the rubber switch boot and steel bezel, so it’s just the top part showing.
allcool
Well, we’ll give it a go, thanks for explaining. Green GITD material around the switch should look good on my d4 black and grey, but not sure on the green d4. What do you think ?
CRX
CRX's picture
I think the green looks good
allcool
Yes the green looks good. Thanks for the pics.
How did you get a smooth tube shorty..? My shorty looks like the one on the far left pic. I must have missed those other options…
CRX
CRX's picture
I just stole that pic from the net Big Smile , I think it’s just a mock up
DB Custom
DB Custom's picture
Does the switch ring thread in or is it press fit? I didn’t remove it when I took mine apart and replaced the FET….
CRX
CRX's picture
I didn’t take mine out, but it’s press fitted
DimWit
Last seen: 1 year 4 months ago
@CRX sorry for the noob question, but what recessed switch did you use as it look almost completely flat with the “wide” portion for the GITD film. Also you mentioned the bezel when titling the photos. Did you re-use stock bezel or replace? Will be taking delivery of my D4 tomorrow and have a few items that are on the list for mods, the recessed switch being one of them. Thanks.
