Anyone for a Astrolux S42 BLF Edition?
In for a blf model Narsil
I think the BLF edition is called the Emisar D4 Quad
but maybe Im wrong
:+1:
definately a better light
Its not gonna happen, either way you modify it or get another small quad
The S42 need another firmware, better FET, copper head, thicker leads, added 7135 and changed head design so the TIR rests on the LEDs not floating 1mm above em
agree
Well said! I have a S41 and if the S42 had a copper head with side switch i’d buy it and 18650 tube… still disappointed by the discounted price on the S41 offered 4 days after my purchase :rage:
Who needs S42 we have Emisar D4 now.
The S42 is availiable in SS with copper head,
can make a really nice light with 18650 tube and a Skilhunt or shortened tailcap if you put in there a TA Narsil driver
Thanks. I missed that option for a copper head. Unfortunately I’d have to buy 1 stainless with copper plus one aluminum and long tube to bake plus driver and spend well over $100 for the equivalent of a S41 with a side switch in the color I want.
well, a charging option is nice and the lit button.
And the LEDs are high CRI
Another board with charging would be nice
But as a stock light it’s a I will never this crap again.
I would buy a BLF S42 if:
USB was gone completely,
Copper head, aluminum tube and cap
Nichia high cri emitters
Narsil firmware
Otherwise, like other’s have said, what’s the point when the Emisar D4 is here and works the first time out?
Me too. Sounds great.
D4 lacks onboard charging. A BLF S42 that was sorta like a slightly larger D4 onboard charging could be worth it.
I would NOT want a copper head on this light. In my opinion, copper heats up too fast around the switch button and is too heavy for comfortable pocket EDC.
Personally IMO, onboard charging is one more thing to go wrong, especially on a light like this. I don’t even use the usb charging on the Acebeam EC50 G2 since it takes 6+ hrs to charge it. Easier to change the cell. I love the copper head on the S41, one of my favorite lights. albeit, there’s no switch on the head.
it may be possible to do a TA driver that could be replacing the contact plate, the tricky part is to get the clearance for the 2 rods to solder on
if I had the distance and size of those holes I could try it
You stole my line!
@Lexcel, dann noch eine Kupferscheibe 0,8mm dick unter das LED-Board
+1
Yeah i dont use on-board charging and i prefer flashlight without it but i know everyone is different.
Astrolux S42 driver designed
If you remove the small MCU on slave board you can use charging without the parasitic drain from breathing sideswitch LED
Running NarsilM
FET+6+1
sale topic
