Here is the first revision of a schematic for my own boost driver. I decided to go with the MP3431 instead of the MP3429. They are basically the same chip but the MP3431 has an optional input current limit pin if we want to set a limit below the 21A switch limit.
I’d like others to look over the MCU circuitry and see if I am missing any critical features we might want. Right now I have included both a driver mounted thermistor and a port for an external thermistor, as well as a port for a momentary switch. Then we just have battery voltage input. Once I get the schematic mostly finalized I will start trying to lay out the PCB.
I hope you are able to complete this project successfully. There is a need to advance the hardware of BLF drivers to catch up to the wonderful firmware available. Unfortunately this wonderful firmware is limited to mostly linear drivers at this point in time.
In your schematic you have an ntc resistor as well as ntc resistor port. Will this give the firmware two separate thermal data points to control temp? Or just one or the other?
Hardware will support both, so really it’s up to the software. Supporting both at once was the plan though, at 20A input current the IC will be shedding a lot of heat so driver temp may become important.
Very nice! I just had this image in my head of a graph charted and recorded by an MCU. Then able to load that information back to a computer for easy observation of heat flow. Or an MCU in calibration mode that monitors the heat flow on any given level and calculates the best thermal performance for that particular setup.
Edit: After reading this, it sounds the same as what BLF firmware is already doing. However, it’s different in my head anyway. Maybe just more detailed and more complicated than needed. :person_facepalming:
The lower resistance the sense resistor is the higher the output ?.
I was changing the emitter in my C8S and damaged the sense resistor, I don’t have a R025 but I have a R018 but I think that’s a to low value making the driver over heat?
I went ahead and changed the resistor to R018 and the driver works .
It steps down fast and starts to blink, but at least it works. I don’t know if I damaged something else when I shorted the reflector but I will try to find a higher value resistor and see how that works out.
Just the fact that I made it work again I consider a victory I am more of a solder two wires kind of guy.
hi, i am using the KX70 32mm “6V” Boost driver in a courui d1 with a xhp50.2, powering from some good keeppower protected batteries, and notice often that something shuts down the flashlight in middle of using it. it would require me to remove the battery to restart it. it seems like the batteries are going short or something in the driver is failing, have you observed this?
I have not experienced that on any of my samples no. What current is the protection rated for? The driver can pull up to 10 amps from the cells depending on output and charge level.
solRNY, protection circuits are an additional hurdle which reduces a cell's discharge performance. Your protected KeepPowers are more than likely low drain cells with standard discharge protection circuitries, causing additional output voltage sag. The equivalent series resistance in one of those protected batteries is equal to the internal resistance of its low drain cell (high, above 50-60mΩ) plus the resistance of the probably two 8205A MOSFETs (close to 15mΩ) which switch the cell's cathode. This is very high and completely inadequate for even remotely close to high drain applications.
A high drain cell's internal resistance is generally well below 30mΩ. Mooch, the vaper's community reviewer, concluded that low drain cells are only worth it at up to half of its rated maximum discharge current (or so) versus the 2800-3000mAh high drainers. It can be argued that the test's cutoff value is very high (3.2V) and I agree, but anyway it serves as an enlightening reference: Which High Capacity 18650 is the Best? -- Shootout Bench Test Results @ E-CigaretteForum
V1 posted on Thu, 08/10/2017 - 15:17; redundancy typo fixed.
No relevant information found for the driver. My observations:
Reverse polarity protected. As Jensen567 explained in this same thread some messages ago for the H1-A, this means the driver innards' ground plane is isolated from the host, which is heat transfer detrimental.
Amount of modes and spacing: 5-40-100%, with optional strobe and SOS. :THUMBS-UP:
Last used mode memory, 3 seconds. :THUMBS-UP:
Stock output is 2.2A, sense resistor :facepalm: 0.1Ω , 0.22V sense voltage. This is inefficient, a lot of power is lost here.
Height is listed as 8mm, spring excluded I believe.
Sheesh!
It's 17mm, but wrong in every other aspect. An LD-29 beats it hands down.
I have a couple of those on the way already actually. Im guessing it is QX9920 based but will find out. Plan to use them in some converted mini-mag triples, so not going to push much current.
I have a Sofirn SF30A on the way from Aliexpress because of this tread on TLF, I have a “spare” driver from a Jaxman X1S I plan to use with a XHP35 HD.
Thanks for the link, khas. I'd have preferred for those %@#@&$ not to “hide” the pictures.
Something is said about the led sitting 5mm “too low”, or the lens not being able to get close enough above the emitter, limiting flood. Don't know how do they solve that.
Mine isn't going to be fully modded “straight away”. As it comes from the warehouse I'll just put a dedomed emitter in it.
I'll probably go with an XHP35 in a near future, for now I'll just swap the stock XM-L2 with a dedomed XM-L2/XM-L, the stock driver isn't meant to handle high voltage emitters.
The XM-L I have is an old school emitter, produced maybe by the end of 2013, this means it can probably take some high current without blowing up.
I see the H2-C manages ≈2.5A in turbo at 12+V with ease and efficiency, at least as long as the input is 2S. How about stacking an R050 (or two R100s) in parallel with the stock ones? That would mean 3A for turbo, 2A after 60s stepdown. I'd just need a Sinkpad XHP70 6/12V MCPCB.
