[PART 1] Official BLF GT Group Buy thread. Group buy officially closed! Lights shipping.
when will this available? Im on the first list and definitely don’t want to miss out!
Will this light have regulation…and no step-down?
Any recommendation for Aliexpress seller that:
- Sells genuine batteries &
  • Suitable for this light
(gearbest / Banggood are not suitable since they no longer ship here…)
Hey,
Just want to say i hope the team will suggest a better finished reflector (less ‘rings’ etc…)
Because this light is basically as good as its reflector will be.
Hold off buying cells, we need to know more about carrier improvements first
Cool thing is that Lumintop wants to sell their cells of course so that adds another motivational factor in getting the losses as low as possible :wink:
Yes reflector smoothing is on the list.
Hhmm, some may think regulation is step-down, or do you mean full temperature regulation that lowers and raises amps based on thermal sensing?
This is a very large mass light using a LED that has to be run amp limited with 3A or so considered the upper threshold. It takes a pretty long time to heat up in the protos, even without any thermal grease on critical junction thread connections.
I'm hoping the production units will have some moderate amount of thermal grease on the thread connection of the pill to head, and if so, it may be unnecessary to have any thermal regulation, but at this point we are considering a 10-30 minute or so default step down. Right now the firmware has only step down capability based on time or MCU measured temperature. I'm not sure with full temp regulation on the MCU based temp sensor because of it's location and calibration issues. If we used an external temp sensor, we would have better options. Again, really dunno yet whether any regulation is necessary - still early, still testing, etc.
Again with the NarsilM based firmware currently, step-down is supported via temperature or time, but fully configurable by the user, and can be fully disabled as well. We will consider though non-stop usage scenarios, search&rescue etc., in warm environments.
I think next step we need to order some good case or holster for GT.
I’m not sure about a holster, in fact I may very well appropriate my sons little red wagon to cart this bazooka around. Either that or enroll in cross fit training to get in shape enough to wear it in a backpack and be able to walk for more than 10 minutes before passing out from exhaustion.
I found a backpack designed for camera gear that will fit it for $13.00 from a seller in China. :slight_smile:
Ok, thanks! :+1:
I’m pretty sure he’s talking about voltage/current regulation. :wink:
Which is strange, since it has a buck driver that does offer full regulation. I am lost what the complaint is even about.
Did he mix up the Q8 and the GT?
i usually open multiple tabs at once and the thread title become truncated. If TheMiller could change the title a little into something like “GT: First prototypes have ARRIVED, a BLF special giga thrower” Instead of “First prototypes have ARRIVED The GT, a BLF special giga thrower”
That first word could give a clue as to which thread we are reading. Sometime i replied to wrong thread :smiley:
Yes can and will adapt the title, thanks good idea!
Thanks The Miller :+1:
Has the price been decided, advertised, available? I think I asked to be on the list a few weeks back, but please add me just in case.
The first 555 the cost will be $111, for all remaining orders it will be $150.
Retail price after the GB is planned at $249 but figure you will find coupons to knock it down to $200.
Found one:
https://www.amazon.com/BLF_GT_Holster/dp/B01N30MACN
Sounds good. Thanks!
nice to see this crazy thing exists now
this light is sooo useless (for me) and huge, that i want it so much!!
btw, i recommend to compare it with Maxtoch Shooter 2x
i`ve tested about dozen of throwers, no one could outperform it.
guys from fonarevka bought it after my russian review and wrote it performed better than olight 3x javelot
