Hey,
Just want to say i hope the team will suggest a better finished reflector (less ‘rings’ etc…)
Because this light is basically as good as its reflector will be.
Hold off buying cells, we need to know more about carrier improvements first
Cool thing is that Lumintop wants to sell their cells of course so that adds another motivational factor in getting the losses as low as possible
Hhmm, some may think regulation is step-down, or do you mean full temperature regulation that lowers and raises amps based on thermal sensing?
This is a very large mass light using a LED that has to be run amp limited with 3A or so considered the upper threshold. It takes a pretty long time to heat up in the protos, even without any thermal grease on critical junction thread connections.
I'm hoping the production units will have some moderate amount of thermal grease on the thread connection of the pill to head, and if so, it may be unnecessary to have any thermal regulation, but at this point we are considering a 10-30 minute or so default step down. Right now the firmware has only step down capability based on time or MCU measured temperature. I'm not sure with full temp regulation on the MCU based temp sensor because of it's location and calibration issues. If we used an external temp sensor, we would have better options. Again, really dunno yet whether any regulation is necessary - still early, still testing, etc.
Again with the NarsilM based firmware currently, step-down is supported via temperature or time, but fully configurable by the user, and can be fully disabled as well. We will consider though non-stop usage scenarios, search&rescue etc., in warm environments.
I’m not sure about a holster, in fact I may very well appropriate my sons little red wagon to cart this bazooka around. Either that or enroll in cross fit training to get in shape enough to wear it in a backpack and be able to walk for more than 10 minutes before passing out from exhaustion.
i usually open multiple tabs at once and the thread title become truncated. If TheMiller could change the title a little into something like “GT: First prototypes have ARRIVED, a BLF special giga thrower” Instead of “First prototypes have ARRIVED The GT, a BLF special giga thrower”
That first word could give a clue as to which thread we are reading. Sometime i replied to wrong thread
nice to see this crazy thing exists now
this light is sooo useless (for me) and huge, that i want it so much!!
btw, i recommend to compare it with Maxtoch Shooter 2x
i`ve tested about dozen of throwers, no one could outperform it.
guys from fonarevka bought it after my russian review and wrote it performed better than olight 3x javelot
Well I plan on zoom my camera on the castle tower 820m away and compare the sample with the current king of throw TN42 (should be little throwier then the Shooter 2x)
There really is no comparison. I've modded a couple early Shooter 2X's, maybe got about 360 kcd (1200m) - think that's the rating of the dedomed XM-L2 U4 version. At 1.1 Mcd and in sheer size, no comparison.
