Would it be acceptable if I offered up some excess “working” Soraa Mr16 gu5.3 12v lights (for free)
“working” is defined as they make nice light but seem more dim then the others I have. maybe a flaw maybe just lower voltage.
unit
To the community to use as they see fit for contest purposes.
I believe the relevant rules are:
You may use some manufactured components such as; reflectors, P60 drop-ins, drivers, LEDs, “O”-Rings, switches or lenses
You may not use manufactured flashlight parts such as: a bezel, body, tail cap or head
Right now I have 5 2 left (Jensen567 already has his in route)
one or two each depending on demand.
Fancy emitters high cri and a killer heatsink I thought maybe they would help a modder out there?
Nice to see this running into the 5th year! sadly life’s headaches and obstacles, added with work loads this summer I have to sit this one out again. ( second year in a row >.<) hopefully next year i can re-join in on the build contest action. For now i will cheer-on all the competitors! :sunglasses:
Congratulations on getting another one going. No promises as those are already tied up but if I can I’ll see what I can do after other commitments are fulfilled.
Your right. Unfortunately times short. I’m not sure whether to build a light I may finish or one I wont finish when l get a start. :person_facepalming:
I’m going to try and get one entered this year. Even though I’m not planning on using a mill or lathe, or any precision cutting machines, I think I’m going to end up in the machine made category.
