I just received my first (18350/219C) and it is insanely bright for it’s size.
Quality is superb and UI is a new masterpiece from ToyKeeper.
Now I just have to figure out a way to attach it to my keyring…
The lumens for the blink are one of the only things that bother me on this awesome light. I keep it manually locked out often and then in the middle of the night twist the bottom to have a pretty bright double flash in a dark room with eyes adjusted to the dark.
reserved
Post #1,000!
Oops! Did I do Thayat?
For the blink-on, You can always cover the head while screwing the tail cap on. Or close your eyes for that brief instant.
Edit: If you’re powering it up, your dark adjusted eyes are fixing to require to some adjustment anyway, right? lol Master the click and hold so it starts in moon… been doing this for a few years now with TK’s own ramping firmware. Wink
Sorry, couldn’t help it. Must be the pain. Or the meds
Has anyone tried the Nichia 319 in this D4? Wondering too how 4 XP-E2 in green would work out? Too much power? Maybe if using the 18350 and avoiding turbo when a fresh cell is installed?
Here’s just to verify what is obvious. Efficacy stays exactly the same on lower output within the 7135 range. Little nicks on the orange graph is me bumping into the setup while cleaning…
Very useful information there maukka, thank you!
When you’re done cleaning you can come over here….
i read you earlier comment, raccoon city made the 1000th post so nothing wrong with you :partying_face:
lol someone probably deleted their comment and made you the 1000th post
Yup, you guys are definitely a bad influence.
Nah, I bet you are truly grateful.
the green look nice, i hope i dont regret buying the green one.
My green D4 with N219C’s came today.
Even with a Panasonic NCR18650B cell it still get’s hot on Turbo and starts stepping down fairly quickly. Seems to me the tube is robust enough to bore it for a 20700…. will see about that. If I kill the long tube it’s not a big deal as I like the short configuration anyway.
Has anyone installed a TA Driver in one of these? I was thinking about it to significantly improve the efficiency of the medium modes considering how high Turbo is…
You are my bad influence. Haha. Ordered one green piece after seeing your pic.
Yup, you guys are definitely a bad influence. !{width:50%}http://i.imgur.com/hJNnceh.jpg!
Swapped out the 5A2 XPL HI I had in one of my D4s for 3A XPL HI last night. Tint looks a very pure white, much cooler than before. Cooler even than 3D.
Might be a bit too cool for me. Next thing to try is a mix and match. Perhaps two 3A + two 5A2 or maybe three 3A + one 5A2
The green color made me buy it. A birthday present to myself. My birthday was Aug 9, so my birth stone is Peridot, which is lighter in color yes but close enough. So if I can get it outputting green light as well, the inner Green Lantern will be happy. ROFLMAO
Hello
Which holster do you recommend for this FL?
Thank you
