I thought the redesign of the carrier consists of plastic rings around the positives that will only accept button tops. At the same time this is the reverse polarity protection. Of course you can easily remove the plastic thingies.
For the retail model, battery carrier/ holder will be extended by 2.5mm and spring height shorten by another 0.8mm. In my opinion, having a button top battery could:
reduce the chance of loading the battery in the wrong direction.
maintain a good tension between the battery and spring. Generally, loosely fit battery can cause temporary disconnection upon impact or vibration.
Button top is not mandatory for Astrolux MF-01 based on what i have been briefed so far.
I guess depending on the thickness of the rings, you might be able to solder blob your batteries. I think this is a situation where we have to wait until the product ships to know for sure what batteries will work. Assuming you want to keep the polarity protection in place.
Many thanks for the sweet deal! I ordered the XP-G flavor. This is the 4th light I’ve bought in the past week. MT-01, Klarus XT12GT, Emisar D4 with XP-L HI flavor, and this bad boy. Also ordered some batteries and the new Nitecore superb charger SC4, and the Liitkola?500 charger. I’ve got to quit buying stuff. But the deals are too good to pass up…. :+1: :innocent:
It would be nice if Banggood could put the final lumen numbers on their web page, the ones they have now don’t seem right. Maybe fix the Sumsang mistake while they are at it.
Adding a 2500 lumen level would be nice too. So many of these four cell lights don’t have a medium level, they just go from really bright to not so bright with nothing in between.
