Review request for HKJ [USB Power Devices]
There’s two USB ports on the thing. For reference, on the Omnicharge (similar adjustable power bank) I measured 126 mVp-p and 22 mVrms from its USB ports at 1A. On the QD188 USB1-port I got 310/90 mV, USB2-port was ridiculously bad at 1800/410 mV (yep, that’s 1.8 volts peak to peak). Not much difference between 1 and 2 amp load.
I don’t have a very good cable setup for measuring ripple from the dc out, but at 12V/1A the QD188 was about the same as the Omnicharge at 356 mVp-p and 106 mVrms.
edit: disclaimer, the batteries on the QD188 were almost empty when I did the test
edit2: was able to bring down the noise a bit on the QD188 USB2 (1800mV to 800 mV) by using a different usb power bank to power the ZL1100 load. Should probably use a resistor instead to eliminate all other possible source of noise.
Oh thank you. Is that a ds1054Z you used to test ripple?
Mmm maybe I am going too off topic. If I am correct, may I write you a PM, just in case I have some questions about it?
review request:
I noted there has sprung up a number of USB power meters lately:
a) Satechi USB-C power meter (I think someone may have mentioned this already - for USB type-C only)
https://www.amazon.com/Satechi-Multimeter-Chargers-External-Capacity/dp/B01MT8MC3N
b) King Meter Power-Z KM001 (Std and Pro versions) USB power meter [the item looks very similar to YZXStudio’s model ZY1276]
Power-Z KM001
https://www.aliexpress.com/item/KINGMETER-Power-Z-High-Speed-USB-Voltage-Ammeter-QC-PD-Decoy-Coulometric-Meter-TYPE-C-Test/32816157844.html
or (the link below contains link to the item’s software download and manual; the software is still ‘beta’ or more likely ‘alpha’ stage; I tried downloading and running the software [without having the USB power meter] and the software is a mix of English and Chinese, on my English Windows 10)
https://www.aliexpress.com/item/POWER-Z-USB-tester-QC3-0-PD-Digital-voltmeter-amperimetro-Digital-voltage-current-amp-volt-Type/32820662689.html
[update: seems like there is a Power-Z KM001 and a Power-Z FL001; the Power-Z FL001 looks like a clone of the ZY1276; but YZXStudio seems to start to announce a new smaller sized ZY1275 that looks to be a clone of the Power-Z KM001 —- these are just my guesses based on the scant info (for now) I’ve seen while browsing around]
(there’s a review/first look (in Chinese, but lots of pictures) of the Power-Z FL001: 惊喜!升级版POWER-Z FL001上手体验 - 充电头网
and the Power-Z KM001: 您与大神只有一个黑金表的距离 POWER-Z KM001之初体验 - 充电头网
including both KM001 & FL001 being used to test a RavPower 26000mAh power bank: RAVpower 26800mAh 双向PD快充移动电源拆解评测 - 充电头网)
ZY1275
c) Kotomi (Plus and Pro versions) USB power meter
https://www.aliexpress.com/item/Kotomi-high-precision-TFT-USB-current-voltmeter-QC-PD-trigger-PD-test/32819095841.html
- or - (the description of the link below has more detailed references; the feedback section of the link above has an English translation of
the features comparison table)
https://www.aliexpress.com/item/Kotomi-Pro-High-Precision-Color-USB-Current-Voltage-Meter-Capacity-Coulometers-PD-QC-Trigger-Line-Resistance/32817004758.html
For Power / Energy logging, I had a VoltCraft Energy Logger 3500 for a few years now, I wonder how it compares with the ZhuRui PR10 Power Recorder. But it seems the VoltCraft Energy Logger is not being sold anymore…
Thanks, I will be looking on some of these meters.
Now I also needs a real usb-c power supply with 20V 5A, anybody have a good idea where I can find one.
With power/energy meters I prefer to test currents ones, I have publishes a test of one more and I have one more in queue.
How about these 87W power supplies:
https://www.amazon.de/dp/B01MQB29GV/
https://www.amazon.de/dp/B071KSKDFJ/
Anker already offers 60W:
https://www.anker.com/products/variant/PowerPort-Speed-1-USB-C-Port/A2015111
I found a powerbank with 100W USB-C:
There’s a review of USB-C power supplies in the german c’t magazine:
https://www.heise.de/ct/ausgabe/2017-6-Vier-Steckernetzteile-mit-USB-C-Buchse-im-Vergleich-3635812.html
The Apple one is the most interesting one, but I am lacking more detailed specifications.
The c’t looks (You have to pay for the full article) to be about the same usb-c types I have been reviewing, not the smart ones.
Apple is not the best solution for technical innovations (first iPhone even hasn’t GPS and UMTS like Nokia had).
Found some Chargers up to 90W:
https://www.google.com/shopping/product/8915748415385534437/?prds=scoring:tp
https://www.jacob.de/Netzteile/Notebooks/hp-inc-adapter-904144-850-artnr-3692667.html
http://www.caldigit.com/thunderbolt-3-dock/thunderbolt-station-3/index-eu.asp
http://www.belkin.com/de/p/P-F4U095-APL/
http://fsp-europe.com/de/power-supply-units/
http://fsp-europe.com/de/usb-car-charger-shining-16/
There’s a QC 3.0 device list, maybe there are some more power supplies listed.
That is not what I am looking for. I has to be a USB Type-C charger with 100W, not a Quick charger or docking station (That delivers power on some other connector).
I don’t understand why output has to be 100W, yet there are no known devices which can request 100W power.
It do not need to, but for testing it would be nice to cover the full usb-c power range. I nothing better shows up I will probably start with the Apple.
Would be interesting :slight_smile:
Found another USB Type-C voltmeter:
https://www.amazon.co.uk/Plugable-Amperage-Direction-Indication-Construction/dp/B01NAWYSVK
And thanks for the now brand new JustMobile AluCharge review :wink:
How about:
https://www.aliexpress.com/item/CY-USB-3-1-Type-C-USB-C-Female-to-DC-5-5-2-5mm-Power/32468388154.html?
  • a 20A 5V Meanwell-Power-Supply?
What I want is something that understand and reacts to the usb-c commands for power delivery. This is much more complicated than Quick Charge and not something I want to make myself.
Hi, i did find some new and interesting devices (usb power supplies/chargers).
Could be interesting for your queue :slight_smile:
Most interesting would be your review of the YZXStudio Power Bank:
Powerbank which delivers 3A/5V via USB-C:
USB charger with reversible plugs (so work with every cable besides the reversibled ones like fom Blitzwolf)
http://www.raidsonic.de/en/standards/searchresults.php?we_objectID=3559
USB charger with integrated Current and Voltage meter for 1/4 ports (1x QC2.0)
http://www.raidsonic.de/en/standards/searchresults.php?we_objectID=3373
USB charger with current and voltage meter for every of each 6 2.4A Ports:
https://www.amazon.de/dp/B01N07MW4G/
12V car USB charger with very slim case:
Saw another energy/power meter from ZhuRui-Tec:
LPT200 Lamp Parameter Tester (the name says it’s designed to test LED lights, but the item’s description notes that it can be used to test electrical consumption of most electric appliances)
https://www.aliexpress.com/item/LPT200-LCD-TFT-lamp-tester-AC-power-meter-2500W-power-energy-kwh-voltage-current-substitute-for/1564283122.html
I bought this one a few weeks back and was rather annoyed when I got it. Plug in my Nexus 6P, plug in my USB-C supply and it’ll show ~1.7A and wont “fast charge”. The phone realises something else is in line and doesn’t fast charge. Annoying.
I may look at them later, just know I have enough in queue
I doubt it, it is rather difficult to get ready made.
I have already reviews that usb charger, probably with another name on it.
I will think about it.
Review is nearly finished.
[quote=HKJ]
http://lygte-info.dk/review/USBPower%20Usb%20fast%20charger%206%20port%20WLX-899%20UK.html
Converting any USB QC power source into an universal 5-20V power adapter:
https://www.aliexpress.com/item/1PCS-QC2-0-qc3-0-Tester-Automatically-Detects-Phone-Quick-Charge-Voltage-Meter-Simulator-Trigger-9V/32771660912.html
I have looked at something like that before: Test of USB QC2-3-MTK-PE Trigger J7-t
One problem is that it can easily damage a normal usb device, because the output is a usb connector.
I have ordered one, if I get the time I will review it.
