I am amassing too many lights for the minimalist in me so I'm selling some for very reasonable prices here.
All lights are tested and work fine. First come first served. No returns.
First post or PM "I want the..." etc reserves the light until payment (24hrs)
Payments via paypal. All lights are modified/ used/ hand made so don't expect a perfect specimen.
International shipping usually costs between $10, £8 (Untracked) and $16, £12 (Tracked)
I may add more lights from time to time.
Sensible offers will also be considered ;)
Thrunite T10T Titanium XHP50
Sold :THUMBS-UP:
Titanium body
Cree XHP50 J4 1A on Noctigon
Sanded Reflector
ARC Glass
MTN15mm FET Driver
GuppyDrv Firmware
Reverse Clicky Tail Switch
Green GITD Bezel & LED Surround
Green Tritium vial in lanyard hole
14250 x 2 compatible (Included)
Max - approx 1700lm
This is a used/ modified light so has some imperfections.
Sunwayman V10R Ti+
Sold :THUMBS-UP:
This also comes with a free AA extender which was hand filed to a round shape and the rubber switch boot
Titanium
Triple XP-L HI V2 1A on Noctigon
10507 TIR
ARC Glass
Magnetic Control Ring Driver
Forward Clicky Tail Switch
Green GITD bezel insert
Green tritium vials at tail
Graphite aesthetics
16340/ 14500/ AA Compatible
Max - 700lm
TrustFire Mini 01 Triple XP-G2
Stainless Steel
Triple Cree XP-G2 S4 2B on Noctigon
Stock Driver
3 Mode - High, Low, Strobe
10507 TIR (No glass)
Tail Reverse Clicky Switch
16340, CR123 Compatible
Splashproof
High - 600lm
Low - 70lm
Strobe - 280-420lm
Manker E14 Quad XP-L HI
Aluminium/ Copper
Quad Cree XP-L HI V2 1A on copper MCPCB
MTN 17mm FET Driver
GuppyDrv Rev1 Firmware
18350 tube with Forward Clicky & Green Tritium vial
18500 Hand Made tube with Reverse Clicky
No 18650 tube
Green GITD tape inside head
Max - 3000lm - Samsung 30Q
Max - 2500lm - Aspire 18350
Max - 2100lm - NCR 18500B (Included)
Klarus Mi7 Titanium
Sold :THUMBS-UP:
Titanium
Cree XP-L HI V3 1A?
Stock Driver
OP Reflector
ARC Glass
GITD Around LED
Electronic Side Switch
Tritium Vial
Magnetic Tail
Graphite Aesthetics
CF Lined battery Tube
Bypassed Spring
No Clip
High - 630lm
Low - 78lm
Bamboo Kubatan
Aluminium (bare)
Cree XM-L2 T6 4C on Noctigon
Nanjg 105c 3A Driver (2 mode)
OP Reflector (Some dust specs)
Reverse tail clicky
14500 Compatible (Included)
Splashproof
High - 1030lm
Low - 106lm
This is a used/ hand made light so has some imperfections and is not servicable.
CRX BumbleBee
Brass & Copper construction
Nichia 219C D320 5000K on Noctigon
Direct Drive (Resistor limited to 1A)
Mule
ARC Glass
Tail Twisty
Magnetic Tail
Efest IMR v1 FT 16340 compatible (Included)
Runtime Approx - 45m
Length – 43mm
Width – 21mm
Weight – 57 grams (with cell)
Max - 310lm
This is a used/ hand made light so has some imperfections.
CRX Apollo Light
Sold :THUMBS-UP:
Brass construction
Cree XM-L2 5C on Noctigon
FourSevens PK Paladin Driver
LOP Reflector (some spacedust)
ARC Glass
Head Twisty
Magnetic tail (holds vertical)
2 x AAA compatible or 1 x 10440
Dimensions: 5¼” x 7/8” x 5/8” (battery tube)
134mm x 22mm x 16mm (battery tube)
Weight: 5oz (142g) (with cells)
2 Modes + Hidden
High: 440lm
Low: 25lm
CRX Carbon Fibre Powerbank Flashlight
Carbon Fibre/ Brass/ Steel construction
Cree XM-L2 U2 1A on Noctigon
MTN 10 FET Driver
MoppyDrv Firmware
LOP Reflector
ARC Glass
NCR 18650B non changeable cell
Splashproof
Length – 130mm
Width – 22mm
Weight – 94 grams
Charging Current – 0.5A
Discharging Current – 1.0A
Max - 1300lm
