Your welcome!
Yep, I have a couple horse hair brushes that work the best, the synthetic hair bristled brush will not hold the water base paint very well at all, and then spreads it out kinda streaky,but they work with the petroleum based paint!
Yep, Marketing 101, never use the word "cheap" ...inexpensive, value, bang for buck, cost-effective, economical...never "cheap" (even if it is!). Still waiting for Mountain to tell me they restocked...oh well.
Thanks for the suggestion. How about heat resistance? How do I find the best quality foil available internationally without huge shipping costs?
On another topic, for the last several years I got one good light. Peak Eiger. Unlike D4, it had a springless battery tube. The existence of spring means that one has to do a lot of unscrewing to stop the battery from making contact. It seems that itās best to unscrew the head because it has shorter threads, but thatās still a bigger job than it would be springless. Furthermore, itās impossible to fully remove power
It impacts D4 UI in 2 ways:
It is a necessary step to reliably access the max-7135 mode
Locking the light. I used to make a long turn, make sure that battery rattles slightly and new I did good. D4 has a 6-click. Itās actually more ergonomic because I donāt have to check for rattling. But I know I will forget how many times I need to click. And fiddling with the light in the dark to be able to actually make use of it doesnāt sound like good ergonomics. And even less like fun. It may be possible to loosen the tail cap enough without separating the light into pieces, but Iām not sure how reliable it is (minimal turn make the light blink as if I just connected power) and since the washer is at the wrong end of the threading, the light stops being waterproof.
Unscrewing the tailcap only very slightly already locks the D4 out because contact between tube and tail-pcb is broken, it is not needed to break contact between battery and spring. It works very reliably and is not even dependent on intact anodisation so when that wears out the lock-out still works.
The Nichia 5000K tint is a bit cooler than I expected. Compared to a few of my other āneutral whitesā this feels more on the cooler side. Not a complaint just an observation. Actually when I put them side by side, the Nichia feels the most āneutralā while other āneutralsā feel slightly warmer. Iām starting to like warmer tints so I might have to pick up an XP-G2 5D next.
My only complaint it that the anodization on my 18500 tube is already scratched from inserting and removing the Convoy clip. I guess I canāt expect too much from a $5 tube. Might have to sand down the entire groove to make it look better.
I took D4 for a short walk (buying flashlights is good for health!), have some things to report.
Like said already many times, knurling is missing.
I noticed a quirk in the UI. If I ramp the light up to a fairly high level, wait for thermal management to restrain it an start ramping again, I expect the light to smoothly change output. It jumps to the previously set level and starts ramping from that.
A weird software bug:
Sometimes the light doesnāt notice that I cut off the power. It doesnāt blink on power-on and doesnāt reset mode to 350 mA. Happened twice accidentally, I couldnāt reproduce. Then after playing some I tried to do it again and it happened: there were no blinks. But then I noticed more: now I can reproduce it at will, it happens every time. I think this may be because I have not turned the light on since it happened, thereās some flash state that makes the light not notice and turning it on resets that.
I like the tint.
Very floody, but still less than I was afraid of.
Everybody knows it, but the output is good.
I thought about that. There could be a minor LED temperature improvement by replacing solid trays with vapor chambers. Or actually large portions of head. It could also make powerful lights (D4 counts) slightly shorter. Likely too expensive to be worthwhile.
You could use heat pipes to spread heat over large heatsinks. It could make them more effective, making monster lights a bit brighter.
You could also use something like paraffin wax to increase thermal capacity and thus increase turbo duration.
Ha ha good point! Well i spent $42 with the tracking , think I may be the only one with no 18350/18500 tube thoughā¦ā¦ā¦ā¦.for me the 18650 is compact enough and it eats through one of those fast enough
