We have a survey on the Turkish mail, and if it has been put into use as one of Gearbest shipping options, we will update info and let the public know as soon as I can.
β CREE XHP35 HD E4 LED with higher photoelectric efficiency, max output up to 1600 lumens
β 18GT - 36 3600mAh 18650 battery included ( installed in flashlight )
β Intelligent battery load system compatible with a wide variety of batteries
β Robust stainless steel bezel ring protects components
β Patented dual-switch tail cap for easy tactile one-hand operation
β Digital intelligent charging algorithm with currents up to 1A
β All new ITS system monitors internal temperature and adjust output to regulate heat, protects LED and internal components for perfect balance of output and safety
β Front and rear internal mounted springs protect against shocks and drops
Brinyte DIV12S CREE XML - L2 Diving Flashlight, A newly wonderful design of led tech diving flashlight with power indicating function aiming to enhance the safety of underwater diving.
Before your diving, the flashlight will remind you of battery low power by lighting a red ( less than 30pct ) or flickering red ( less than 10pct ) indicator next to the magnetic switch
If the indicator turns red while you are diving, which means you should go back to the land as soon as possible
Built by high strength aluminum AL - 6061 - T6 material with premium military type III hard-oxidation treatment
Powered by one 18650 rechargeable battery ( not included), can be continuously lighted for 2 hours under 1000 luminance and for 15 hours under 150 luminance
10-degree narrow beam, the light is the best choice for night diving and scuba diving as the backup light
Over-heat protection design to ensure working stable and safe use; reverse polarity protection to prevent from wrong installation of battery
Two O-ring offer extremely waterproof capability of maximum 100 meters underwater
The toughened lens with thickness 5mm to ensure excellent ability to resist water press
β’ Using high-quality CREE XHP35 E2 bead with long lifespan of more than 50, 000 hours
β’ Max output up to 1300 lumens and throw distance of 228 meters with one 18650 battery
β’ Patented triple tail switches and a side switch for one-handed operation with ergonomic switch locations
β’ Patented JETBeam triple tail switches allow tactical mode with one-touch strobe and simplified outputs with high as default
β’ Convenient side switch allows 5 intensity selections ( excluding turbo and strobe ) with memory function
β’ Intelligent temperature control system to maximize lifespan of LED
β’ Low power indicator function reminds user of battery replacement in time
β’ Reverse polarity protection to prevent damage caused by improper battery insertion
β’ Built-in rechargeable 18650 battery
β’ Both clip and tactical ring included in package for different applications
β’ Toughened ultra-clear mineral glass with anti-reflective coating
β’ Constructed of aero grade aluminum alloy
β’ HAIII military grade hard-anodized finish
β’ Waterproof rating: IPX-8 ( 2 meters underwater )
β Action camera light
β Onboard sliding diffuser
β Utilizes a CREE XP - G2 LED
β Max output up to 360 lumens
β Max runtime up to 235 hours
β Micro-USB rechargeable with onboard charging circuit
β Universal mounting rings to secure the GP3 onto action camera mount
β 7 brightness levels: hidden turbo - high - medium II - medium I - low - hidden strobe - hidden moonlight
β Utilize a CREE XHP35 HI bead that can produce a blazing 3000LM illumination
β Waterproof IPX-8, suitable for usage in rainy weather
β Lightweight, easy to carry
β Powered by 4 x 18650 Li-ion battery ( not included )
β SMO aluminum reflector with double side AR coating glass lens for extreme reflector performance
β Lockout function: a single click followed by a long click to lockout the switch, repeat to unlock
Main Features:
β’ Finger-sized mini-might flashlight, elegant and compact
β’ 10180 Li-ion rechargeable battery included
β’ Micro-USB charging port, easy to charge
β’ Fast charging, only 45 minutes charging needed, no waiting
β’ CREE XP-G3 LED, max output up to 130 lumens
β’ 2 brightness modes to meet your luminous needs
β’ Professional optical lens design, even-lit flood light, soft beam
Main Features:
β Utilizes Cree XP - L HD LED with a lifespan of 50,000 hours
β 3 brightness levels with a max output 550 lumens
β Powered by one AA or 14500 rechargeable Li-ion battery ( not included )
β Handy and compact, easy to carry
β Red, blue and purple colors optional, gift package best for families and friends
β Digitally regulated output maintains constant brightness
β Detachable body clip for two position installation, easy to clip on your pocket or a hat
β Two ways to select outputs: Tail switching or twist the head
β Made of aircraft-grade aluminum alloy with anti-scratching type HAIII military grade hard-anodized finish
Main Features:
β Utilizes CREE XP-G2 R5 with a lifespan of 50,000 hours
β 3 brightness levels with a max output 110 lumens and max runtime 60h
β Powered by one AAA battery ( not included )
Hey Gearbest, Iβm not if Iβm writing in the right thread, but I have another inventory suggestion:
Amutorch JM70, both 1-cell and 2-cell. Seems like a nice value thrower.
