Q8, PMS SEND TO THOSE WITH ISSUES BLF soda can light
Can I be put on the list? Thanks.
From a few posts earlier.
Appropo nothing, but speaking only for myself, I’d rather they come in at the end of September perfect than they come in at the end of August with issues. Lets give Thorfire time to make them right the first time through.
Absolutely! No hurry, get it right first, and not first to get it wrong.
Wow really happy to see this is coming to reality. Glad i Posted early on to make sure i hit first batch, thanks for all the hardwork guys!!!
How much will the Q8 weigh (without batteries)? I did a search, but I couldn’t find anything regarding this.
Yes will update list later.
Weight is not mentioned? I remember Tom posting it but next time I grab the Q8 I will put it on a scale.
cdjaney, I break contact by sliding cells away from the +contact a few times and go with the lowest I see in say 5 times IR showing.
When normal charging I don’t pay much attention to the IR measurements unless it shows 80 or higher, then I check it a few times for that particular cell.
After playing with D4 for a couple of days I get thoughts “Do I really want Q8 too?…”.
I have both, and I love the D4, but the Q8 gets different use: my D4 does 10 second 2800 lumen bursts on turbo (new high CRI leds), the Q8 does over 6000 for 3 minutes (=18 times longer), the D4 can run contuously tailstanding at 300/400 lumen, the Q8 at 2000.
But I agree that the D4 is something special!
Some bed time reading if you really want to know about the Inverse Square Law:
https://en.wikipedia.org/wiki/Inverse-square_law
Sound is same principle but not the same rule (explained on wikipedia), in case you wondered :slight_smile: :student:
You can always ask a photographer, as flash photography requires a good understanding of when to move lights closer, and how much power you will need if you move them further away…
Also another thread with a deal is: https://budgetlightforum.com/t/-/45779
We were not talking about the inverse square law. We were talking about how the eyes, ears and brain perceive a doubling of either light or sound. It’s more of a psychological thing and not so much a mathematical equation.
Laws of physics still apply, not matter what your brain thinks…
In terms of Q8, max output is still insane if measured or perceived :wink:
True, but that’s still not the subject we were talking about.
The Miller
You said you have the actual production videos. Can you upload them for us?
In biology, laws of physics do apply, but it is a disordered interaction of so many physics equations that no result can ever be calculated. Biologists need a complete different tool set than the clear Newton’s equations, the ‘laws’ that biologists use are an extract of real life measurements that may or may not be applied to new situations. (see also ‘fuzzy logic’ :slight_smile: )
In case of the sensitivity of the human eye you may look for a measured light level/human perception curve and that will certainly not be lineair or simple logarithmic.
Oh cr@p being a bit sick with a mild fever and busy so no time to rest made me forget this
Will try to do it today
Not nearly a production video, a few fragments of some first machining steps. Still nice to see though. :slight_smile:
“Laws of physics still apply, not matter what your brain thinks… ”
Yes.
But.
The IR test function of the Lii 500 is unreliable. I have a couple & love the chargers but just be aware the IR test results are not very reliable.
Check out HKJ’s review for more info.
