"Review": Amutorch Stainless Steel XPG3-S3 AA flashlight [Modded TIR Lenses]
@ vwpieces
Thanks for the link! I didn’t thought about that, to get the holders out! :person_facepalming:
I guess I’ll try those :wink: Last week I got some TIR lens from them but they have a larger diameter…
Meawhile, I found these OP reflectors, that seem to have approximate dimmensions:
Hum, may I ask the price of the one you got from Neal? :smiley:
@ firedome
Thanks you! :wink:
DC-FIX
DC-FIX
Thanks for the help Ronin42!
I spent a while reading the thread, ’cause I’ve never heard about this product! Seems quite nice to give it a floody aspect :wink:
I guess that first I’ll try to get a floody lens or a reflector, and then I’ll try this DC-fix it I can’t find a matching one.
And for what I’ve seen Boaz has been off for a while, so I’ll wait for him to get back :wink:
Thank you very much :wink: :+1:
Welcome, and sent you a PM.
Nick
Hmm, this light with the nichia sounds like a really cool setup. I have a LiPo 14500 sitting around that would work for it.
@ vwpieces
Gonna check it and reply :wink: Thanks!
You bet on that :wink: After giving it a nichia or a warm tint, we’ll become “BLFs” (best light friends) :smiley: :stuck_out_tongue:
When giving feedback to the seller I stressed that giving it a better tint would make more buyers happy! I don’t know if they’ll change it for a stock light, but I’m crossing fingers :wink:
BTW, I don’t know if the pronlonged use of 14500 batteries will damage it or not but, so far, the reason I found for the seller to say that it only takes AA batteries is the lack of a spring (or a solder blob) to make contact on the bottom of the driver. Or the fact that it gets a bit hot on the highest mode.
I “tested” (hand feeling) this light with a 14500 Li-Ion battery to see how hot it gets.
The battery is a Sanyo UR14500P (with a magnet on top to make contact with the driver), and was not fully charged.
After entering the High mode, it took about 2.30 minutes to get extremely hot in the head.
The body didn’t get hot, the light didn’t flicker, it was holding well in terms of luminosity, and it was possible to hold it well in the hands (except the head).
Being a Stainless Steel, thin body, it gets hot really fast, but its temperature drops very fast as well, after being turned OFF.
With a regular AA Ni-MH battery it doesn’t get so hot, of course, but after a minute on High, we start to feel it warm!
Cant wait to order one with Nichia from Neal!
Neal said approx 7-10 working days and will be on holiday next week, so unfortunately i have to wait before ordering :frowning:
Yesterday, at night, I was using the flashlight and I heard a “bzzzzz” coming from it!
At first I thought it was from the battery, so I changed and used different batteries, alkaline, Ni-MH, 14500 Li-Ion, but the “bzzzz” remained.
Then I thought it was because I was messing with this particular light (the one I used for the review, [dis]assembling continuously… ).
I tought it was any damage I had provoked to the driver or the emitter… So I picked up another of these and used it with all types of batteries. Guess what? The noise remained!
So, on Low and Medium settings, the flashlight produces a slight noise (bzzzz), and I guess its due to the driver.
It is not a super noise but it can be detected about 40 cm away from the head, especially in silent environments.
The only occasions I had heard it before was in a Convoy S2+ (3/5 mode driver) when I was using the 3 mode configuration on Medium, and on a Nebo Redline that uses CR2 alkaline batteries (when the battery power is dimming it makes a similar noise).
Anyone has a clue on this and if it is something that can be “solved”? (without swapping drivers, of course :smiley: )
Thanks in advance!! :+1:
Probably the Pulse Widh Modulation you are hearing, i have the same issue with my s2+ on low and medium, not on high since you dont have PWM on high.
It also depends on the reflection of the material (try it) some materials absorb better then others
Hum, that was my guess PWM, but I thought that it would be expectable on high, as well! My mistake :person_facepalming:
By reflection you mean the used material, like TIR lens or reflector + lens?
Reflection, i meant that you can hear the difference between materials. Try it for instance on your car and then listen to the difference when pointing on your tire and pointing to steel or glass parts.
Also the direction of the flashlight makes a difference, seriously, try it :wink:
Edit:
Made a quick video to demonstrate it
Thanks Yokiamy for the video! :slight_smile:
Yup, there is difference for sure!! It doesn’t take out the small noise it has, but directing it to different surfaces makes it less intense.
Since the beggining I’ve been thinking about a driver and LED swap for these lights, and this makes me think a bit more on that, despite overall qualtity is not “endangered” right now!!
Looking at the back side of that TIR, an XM-L2 looks like the ideal fit. May also get you a wider beam angle. The 4C is one of my favorites, I bet 75% of my XM-L2 lights have had them installed!
Hum, I tested and it fits well, you’re right!
An XML2 fits and give plenty luminosity! I guess that it will/would be a better bet than an XPL-HI, on this kind of lens, as I want more flood.
If I don’t get to buy a Nichia or anything with a warmer tint, I’ll buy XML2 T6-4C (and maybe a XML2 T6-3B) from Convoy store an get them inside these lights! I also have S2+ with those (both T6-3B and 4C) and the tint is pretty good :slight_smile:
I have some TIR lens with a more flood beam on the way, I’ll just have to check if those still accommodate well the XML2.
Thanks for the tip :+1:
Wow, I wouldn’t have expected someone to do such a excellent and detailed review of this light,
I’ve got one myself got it for free when I bought the JM70.
They do throw these in as a gift if you buy one of the full size Shadow lights and first thing I did with it when it arrived was put in a 14500 to see if it blows up or not, nope works fine and the driver handles the extra volts just fine, that was a surprise to me actually, this light is not really just some junk give away light but actually a good light, just has a switch that needs adjusting much like the Reylight brass if you have one of those, same kind of switch issue.
I just got a message from Shirkey at Amutorch oddly and I linked your review to him, don’t be shocked if he to is impressed, you may have a great future I think as a frequent reviewer, wow … :wink:
First, thanks for your words :+1:
Ah ah, so that was your comment saying you used a 14500 battery on the SS light :wink:
The seller advises not to use it, and the truth is that it gets really really hot with those! I just won’t try it until it fries the driver or the led, so I’ll use Ni-MH batteries :wink: Mostly :smiling_imp:
Hum, I don’t have a Reylight, but they I felt that issue in the switch, yes! Especially in the one I disassembled for the review. After that it had a somehow strange behaviour, but it’s ok now!!
About this review, I did it because I guess that the more information the members get, the better they can pick a light or not, the better we assess if that’s a light we want to have, as a stock light or has a host, or just for pieces!
That is why I was the more detailed I could. I cannot provide numbers of lumens, candela, throw, runtime, … but concerning its physical characteristics, I’ll try my best in each review I make.
I’ve learned a lot here, and I want to contribute to the forum as well, so this is my part here!!
About the seller/store, I also sent them the link and I guess it was a positive thing, and maybe they can improve the flashlight (I stressed the possibility to have a reflector and a warm tint on it).
I’m not sure if I’ll be a frequent reviewer as money is flying from my account and it won’t last forever. But I won’t say no to some opportunities of reviews if they appear :wink:
BTW, did you do a review of your JM70? :wink:
Thank you for this review, the light is very good looking. I’ve searched and found a seller with almost the same at Amazon.(de)
Got it yesterday (ordered it 04/08/17). There are some slight differences in package/contents: it has a plain brown box with no markings, two (very small) o-rings but no spare switch.
The light itself seems exactly the same as described above. I’ve tested it with a lithium primary battery (Energizer Ultimate Lithium) with 1.5V. It’s bright enough for me and not worth the risk to use a 14500 cell (although the Amazon seller says it’s possible). A stainless steel host is not capable to spread the heat very well, so the small aluminium pill will get very hot if the current is too high.
Hi Antenne!
Hum, I guess that your buy confirms that the o-rings really are very weak, but maybe the switch is not that weak as we thought!
So far I had no problems with mine!
Using a alkaline gives you enough power? I normally use Ni-MH, but it also gets a bit hot after some time! That’s for sure that the host is a bit thin as is the pill.
I’ll make some mods to mine and see if with a different driver and LED it doesn’t get that hot…but maybe it turns out to be hotter…!!
BTW, the seller mentions this: “hoch, niedrig, stroboskopisch” ! Does it have strobe? Which are the modes and in what order?
Thanks for your input :+1:
Nice thorough review with pics to back up your findings. Well done!
