We can ask for it, if Fritz is OK with that. But being a more expensive material I have no idea if LT is going to do it.
Would add to premium look and feel though.
I’m sure most of us would be happy to add a couple of bucks to the order to get a lovely looking, functional clip
I hope it is as pretty as possible … but I am also sure that much of the success in number of requests for this model, is due to expected content price.
Yes with the GT we had no idea what such light would cost, there is no real comparison.
With the Q8 and FW3A it is easier.
So the set price is good, adding a little for A means stepping on a slippery slope for why we are at it, maybe a little extra for B, and C and…
If Fritz is OK with Ti clip we can ask if LT can and want to do it within the budget and see what the answer is. If no we can always ask for an aftermarket clip in Ti. Especially if it goes good and more exotic metals are going to be used for a FW3B, FW3C and FW3T such clip could be sold in higher numbers
Yep, maybe make it an optional extra for those happy to pay a few more bucks?
We have been talking about a titanium clip previously but were not sure if the mechanical properties of titanium are superior when compared to stainless steel. So what you said is quite interesting. Do you have some sort of source where we could read up on that?
Stainless is actually very bendy. It has properties that set it apart from other steels. Titanium can handle most things, depends on the grade. Grade 1 is soft and ductile, Grade 5 is good at most things and can be hardened. Mechanically it would be fine as a pocket clip, not so much as the host itself with it’s poor thermal and electrical properties.
All I know about ti clips is from my own experience, and my experience is that some ti clips are very good (although usually very stiff) like the ones from Moddoo, Prometheus or McGizmo. They’re also very pricey often costing nearly as much as this entire light is expected to cost. On the other hand I’ve also had some terrible ti clips before, ones with zero spring that just bend out of shape and stay that way. I don’t care what material my clip is made from on this light, I just want it to be functional and trustworthy. Please don’t try to shoehorn a cheap ti clip into this build to stay in budget only to wind up with a useless decoration. I’d much rather have a good steel clip than a bad ti one.
Good point emarkd!
The reason for the variance is because there are 50 grades of titanium and 150 grades of stainless steel. The more common commercial grades being sold are a lot fewer than that, but it’s still a lot of different grades.
It depends on the alloy that's used and also the technique used to work it. It has to be worked hot for sharp bends.
It's annealed so it's gonna feel more bendie compared to a piece of stainless of the same thickness. The minimum thickness should be 0.045" to get the correct stiffness (good retention).
Material spec should be Ti6Al4V grade 5. Grade 23 would be better
+1.
Same goes for me! :+1:
I will not talk about the material of the clip, as I don’t have expertise for that.
I have a Manker E11 (I guess it is similar to the Utorch UT01), and they come with a very strong pocket clip, maybe titanium, idk.
I guess it was supposed to be deep pocket clip, but its design and the strength in the last 40% of the clip makes it difficult to put it in a jeans pocket.
This said, besides the material, I guess the design and “functionality” (meaning: a nice looking and well made clip that really accomplishes its functions of being…a pocket clip) have to be taken into account to make it a good clip for the awesome flashlight we’ll get.
Thanks to the folks that have been working on this :+1:
I used to have the problem with my E11 also. Assuming the light is inside the pocket and the clip outside… try pulling the pocket material outward and away from the body of the light as the clip is slid down all the way. It used to give me fits, now it’s easy. If you look at how the clip is built you’ll see why this works. Or to put it another way, why it’s such a PITA if it isn’t done. The material comes up against a hard stop.
+1
Eheh, I figured it out after a while using the Manker E11, the clip works really fine, and the light gets well stored in the pocket.
But my point is that I guess it is preferable to have a clip that is more simple to operate, without sacrificing the safety for us and for the light
But if the work has come that far to make the FW3A a reality, to make a clip for this light will be a piece of cake
We put our trust in you Fritz and The Miller :+1:
The original GB BLF A6 had a Titanium clip and imo was/is a good design but they (still) mess it up by not working it correctly and not using a thick enough material. Then instead of modifying the process and material thickness to make it right they switched to a thicker super hard stainless and continue the same process of manufacture which still turns out a well designed crapily made clip with lower quality metal. (Titanized stainless A6 clip at banggood)
^ I already broke two of those clips at first time putting on.
Yeah I've broken a few also. At least with the original Titanium ones you could heat it up and re bend it.
I reshaped mine (titanium) as soon as I got it and I've been carrying it everyday for 2 years now and even though it's flimsy its still my favourite because of it's deep carry design.
