There are many different discount coupons - not only for specific products but everyday there’s chance to get 11% OFF coupon valid on Sep 07 for everything except Smartphones, Tablets and “Promo” tag Items. Everyone can get up to 5 coupons - there are chances every few hours and there are no conditions - just click +yellow “Pick Now+” button when the counter indicate next round has began.
There’s also a game with various missions (task which are quite easy to perform) - first 110 people who complete all missions will get free Eachine E52 Drone
There’s a catch - final mission is to place an order over $50 on Sept 7 - but that’s one or two flashlights and you can use 11% off coupon which is valid only on that day.
This panel can easily charge any smartphone and will also charge in overcast conditions as well (with decreased rate of course).
Pair with LiitoKala Lii-100 0.5A/1A Li-ion Ni-MH USB Battery Charger for example and you can have independent power source for your flashlight needs:)
This is the most pocketable thrower out there with over 1000lm possible with decent high current battery (to get highest light output spring bypass might be required).
Two LED tints are available: 1A(cool) and 3B(neutral), driver uses Bistro firmware developed here at BLF, turbo mode is direct drive (through FET), low modes are regulated by 1xAMC7135. Lots of mode configurations to choose from (driver is programmable).
What’s more it’s still possible to lower the price further with BG points!!! Prices can be as low as in table below(provided enough points is available):
New Ampcore Plus USB cables are now in preorder with great prices.
Those new version cables have metal plugs and are kevlar reinforced, cable organizer is included.
Only flashlights from the above list can use 17FLANNP coupon code. Collection includes almost hundred flashlights, batteries and chargers from leading brands.
Note: some flashlights have better discounts using dedicated coupons - remember to check list in original post first.
