Hi, Freeme!
PM me a code for the Nichia version please!
XP version ordered. Now for what will seem like the never ending wait…
Ordered in 219C!
Thanks Freeme!
Ordered XP-G3 !
Thanks!
Ordered Nichia version. Thanks Freeme!
XP-G3
NICHIA 219C
It order one by one
Thank you so much, freeme.
oh the waiting! :person_facepalming:
I saw that the link for the 18650s in the OP is for button tops, I thought the light will only accept flat top.
Will it accept both?
No, only button top apparently:
I would get one with Nichia LEDs if it’s possible
… Guess I will go broke soon.
Very cool! I guess because the battery tray works both directions and the battery tube is the same on both ends, that you can run 2 heads.
No one can sneak up behind you. Lol
Wait, that says Mateminco which is also the name on the pcb inside the Astrolux model. Is this light made by Mateminco? Are they the same as Astrolux?
It’s a bit confusing.
Mateminco is Original Equipment Manufacturer! Mateminco MT18 = ASTROLUX MF-01, exactly the same light.
I see.
Once in production the Astrolux version should be the better one due to all the improvements. Right?
The Astrolux preproduction price is $15 more than the MT18. I assume it’s because it’s upgraded or is better tested at the factory. Or maybe higher quality control.
I hope so……we’ll see. However, I see no quality difference in previous products (s41s, s42, k01…etc.)
Any way you could PLEASE post a beamshot or maybe a couple pictures against the wall to compare the nichia vs xpg3 tint?
This wait is killing me!!!
Ilmatic:I saw that the link for the 18650s in the OP is for button tops, I thought the light will only accept flat top.
ENEDED - #199 by freeme
Thank you!
RollerBoySE: Ilmatic:I saw that the link for the 18650s in the OP is for button tops, I thought the light will only accept flat top.
ENEDED - #199 by freemeThank you!
They are saying button top because they want to add plastic rings to the positive posts to protect against installing a battery in reverse. If you dont care about such things you should be able to remove the plastic bits and run flat tops. All up to you.
