Looks like you missed:
2017-08-11 12:28 Germany, Item delivered
Thanks Neal, shipping was super fast and they were well packed.
I have run the normal discharge test of the Lii-500 with 500mA as charging current (discharge current is 250mA in that case I think) 5 times for each battery. For each cycle I moved the battery to the next slot. I was curious about the accuracy of the different slots.
Ignoring the first cycle the avarage capacities of the batteries are:
Battery 1: 1189mAh gained 5mAh capacity after the 5 cycles
Battery 2: 1169mAh gained 15mAh
Battery 3: 1155mAh gained 61mAh - first measurement was 1108mAh last 1169mAh - I wonder if the capacity would increase even further but it just takes to much time to play around more.
Battery 4: 1197mAh gained 36mAh
L4M4: I believe that is for the aspire cells and not the keeppower. At least there is no mentioning about the keeppower cells⌠From reading the aspire test thread I also believe the keeppower is a bit cheaper.
Choose Send money, then Enter amount, then in the âReview and Sendâ step I can choose either âSending to friends and familyâ or âPaying for goods or servicesâ.
