I have been thinking of using EL wire in a flashlight, but what has put me off trying it is what the cheap (few $ from Gearbest) EL-wire with driver does, that produces a pretty loud and annoying high tone. Are there versions that do not do that? (perhaps uses a higher frequency for generating the high voltage)
Maybe it just needs potted.
I want some of these generation two lighted tailcaps.
Maybe we can convince Richard to stock them in his store!
I haven’t looked in depth, but I thought EL wire required like 100-volt alternating current at about 1000 Hz? It would need an inverter and a serious voltage boost and the frequency would likely be audible… I don’t think it works at higher voltage or inaudible frequencies, does it?
I thought it sounded like a fun addition to some projects… until I found out it required alternating current.
The only thing I can think of for some semblance of practicality is a wider body that can house two separate circuits. Kind of like a Spy 007. We could use 2x CR2’s to power the inverter, and maybe a 16650 powering the LED side.
No, it wouldn’t be ideal, but it sure would be attention-getting!
-D
Made another disco tail.
The last one I did had 6 slow colour-changing leds and was lots of fun. The only unexpected effect was that with the 6-led dumb board, every 2 leds share a resistor and are directly parallel, and when at one side the low voltage red led was lighted, a higher voltage blue one parallel would not light up. This led interaction was very interesting to observe but you hardly saw a blue one lighted at all.
Yesterday I did a new Jaxman E2L mod (see the wdymt thread), and today I thought it was neat to have another disco-tail made for it, but now with each led behind its own resistor. It required modding the tail ring. First some traces were cut and solder pads created:
Then the six resistors were soldered, clearing the area where the switch touches the board. The 3 extra resistors were connected to the plus-pad with a thin copper wire:
Then the 6 RGB leds were soldered.
Every tiny component and pad was tinned before soldering down, as I learned the hard way. * Steady hands and perseverence alert! *
The result is as predicted: now all six leds work independently. But they have no synchronised cycle so after switching off the light each time they start together but soon they run out of phase :partying_face: :
OOOOOh, Frik’n cool djozz.
Realy awesome.
+1.
I dont understand whats going on but believe it could cause nightmares if not used with caution.
This is great! I’ve only built one of these tails and I liked it well enough, but mine, just like yours, would “drop” blue within a few cycles. After 30 seconds or so they basically became reds and greens only, mostly reds. I had no idea what caused it but never built another because of it. But now I do! Thank you!
I have Astrolux tailcap switch from BG, the switch comes with only 1 led and 1 resistor (blue 1206 led and 2K 0805 resistor).
Already installed (the same 1206 blue led and 2K resistor) another led and resistor on the other side so I can have balance light from the switch. The problem is, after installation, the original led is very dim, and the new led is bright. Check all solder and nothing wrong. Anyone can help? This is the switch board. Thanks.
Ryley, I may be way off here, so hopefully someone else can validate, but I think you only need one of the resistors.
Actually, I already tested that. Solder the led first with no resistor (only 1 resistor with 2 leds), the result is new led bright and original led very dim. After that I install the resistor, so 2 led and 2 resistor, but nothing change. Same result here.
If one of the leds is original and the other is from a different manufacturer, then that could be it. I would try matching the leds since they might have different internal resistance.
Thought about that too… but now since you mention it, I will try to change the original led. Thanks WillyD!
Would like to share few lights nothing fancy. currently not using any ring pcb/boards, using white 3D printed rings instead of the metal in convoy not so bright compared to rev2 board because of the ring blocking the light looking forward when rev2 boards arrived from OSH.
I have S2+ with metal tailcap, but i’ll wait for rev2 boards as without it the light is just too dim with low current.
Ultrafire 502B, Astrolux S41, BLF A6, Ultafire C8, Convoy C8, Ultrafire C8 (left to right)
Very cool pic, rizky!
thanks djozz.
Use two of the same LED, and probably only one resistor (will probably need some trial and error to get the right value).
Will do that tomorrow night, thanks TK.
Update :
You’re all correct TK and WillyD I change the led with the same and now both are equally bright. Thanks!
Next on Solarforce L2M, still waiting the Osh board.
Just saw this djozz. That’s spectacular. Have you done power draw tests on those color changing LEDs? It’s this kind of stuff that makes me want to come out of modding retirement :heart_eyes:
