Yeesh. That happened to me once, in an office building. This crazy guy Hans Grüber busted a whole bunch of windows and I had to go across that floor… barefooty!
Ouch!
Ouch!
On the bright side, now you got a DTP board…
I was going to write that I “broke” an AT01 (true POS through and through… think they arrive broken), because the switch was going all mental and the thing was going bright, dim, strobe, stutter, etc., but I kindasorta “fixed” it, at least ’til I look at it crooked again.
Looks like a nice light, but it’s not. Avoid, avoid, avoid.
duh i damaged my Convoy S2+ by overdriving it :person_facepalming:
Wouldn’t that be “mod, mod, mod”? That said, I don’t know its base price.
intro:
[image] UltraFire AT - 01 Zooming LED Pocket Flashlight - BLACK @ GearBest [image] UltraFire AT-01 LED Flashlight w/ Focus Zoom @ FastTech Looks like another nice and inexpensive flooder but, any relevant information? Worthwhile mod toy? Cheers [image]
Wheee!
#48 post in “How do you store your batteries?” Some pics: [image] [image] [image] [image] [image] [image]
So… no, no, no.
Broke my D4 driver, I think, when trying to remove it, unsuccessfully :cry: :person_facepalming: . Only other option is that I broke a switch wire in the process, which at least would be fixable. If not, well, I guess I now have 4x 5000k 219c 90+CRI emitters I have to find a new home to
This is a flashlight forum but I just light tipped over my french press & shattered it on my counter :person_facepalming: . I can’t find my spare anywhere. Thus no coffee in the morning for me
Does that count?
Does that count?
You have my deepest condolences. When we lose a loved one here on earth, we gain an angel in heaven that watches over us.
Does that count?
I’ve broken so many of my one mug french presses, finally bought one with a bit thicker glass from Ikea and it has lasted me 6 months so far.
Back to flashlights: I think I broke my mtn fet+7135 driver while trying to solder it to a pill. First three modes are now the same and super dim and then the next 3 go back to how it was before. No idea why I only lost the first 3 modes. Going to take it out and see if something came unsoldered.
I just got my two Astrolux S42 lights which I plan on doing driver replacements. On opening the first one I broke the legs of the optics and shaved off the domes of the LEDs. That nice Nichia tint is now horrible blue… I was a lot more careful on opening the second
Mike C, that looks like the scene of a terrible accident! :cry:
How did I not see this thread until today?
While trying to file down the retaining ring to fit the TA driver from Lexel, i just might have applied somewhat to much force and the retaining ring just snapped!
I believe I actually broke this 3 weeks ago when I attempted the "Mod 2" on my Supfire M6, but I figured it out today (I had to put it away because I was sad when it didn't work and I couldn't figure out why).
Guess I only broke the 105c board. I already knew my soldering iron was too hot for flashlight modding (I accidentally reflowed an emitter when attaching leads to a noctigon...), but now I really need to get a new one. The Supfire M6 is now brighter than my D4, but still has the old annoying modes!
(For reference, this is after I removed it. The sw+ wire should attach there, to the missing star 3. When I had the board installed, the light didn't function at all.)
Hello To all, My reason to join you guys here...
I just broke my week old new OPUS BT-C100 today by insering a charged 18650 reversed.
Sadly I found out that it definitely is not fool proof. The latest fool being me.
It does not have reverse voltage protection....
It still comes on when powered but does not charge as the Q19 is badly fried.
Seems fixable by replacing Q19 but the markings on the Q19 is not ledgable in its fried state so I need you guys’ help to find the part number.
The location of the poor little guy is shown in the link below...
https://www.dropbox.com/s/eeh5uth4uuqllod/You_Doodle_Pro_2018-08-08T21_32_52Z.JPG?dl=0
AND don’t remove the board from the frame frame of the charger for any reason, you would not want to tak a chance and ruin your disolay connector
Cheers and
Thanks
I was removing a MJD41C power transistor (DPAK) from a CCA so I could test it out-of-circuit. The CCA was conformal coated. I had to remove the conformal coating before I could unsolder the part. Next I had to gently lift the emitter and base leads. Next I heat up the collector tab and the transistor slides off the board. I removed the conformal coating, then I went to gently lift the base lead. I lifted the base lead along with half the transistor attached to it. I killed the transistor so I couldn’t test it. So much for that. This was sort of sad because the transistor was doing some interesting things that I didn’t understand. I really wanted to take a look at the transistor on the curve tracer. This may have been a missed opportunity to learn something new.
OOps…
It’s not something I broke, but I just got the news that a close friend of mine that I haven’t seen in 25 some odd years since he moved to Florida in 1988 has passed away. I did see him around in 1993 when I had to fly down there on a service call, but ever since then, it was only phone calls once or twice a week. I’m really feeling bad right now. I met him in 1971 and we became instant audiophile friends. Life is short my friends. Enjoy it while you can. One other thing, we worked in the same stereo store as technicans around 1980. He was the best tech I’ve ever known. RIP Dave, I’ll never forget you pal.
I was potting my DQG Tiny.
I didn’t remove the driver from the host because it’s glued and I’ve seen people breaking their drivers during this.
Some glue leaked to the switch area. I cleaned it up, but I couldn’t do it fully because I lacked access.
The light worked after cleanup, but a day later when the glue remains hardened - the switch doesn’t work.
I used silicone based glue because I thought I could screw something up and wanted something removable. Good choice. Later I’ll try to remove the driver and clean it up better…but I’m going for vacation in a couple of hours and this light won’t go with me.
