The actions: switch flashlight on and half-press the switch more than 10 times until the flashlight stops giving light, wait for first ‘buzz’ and click flashlight off. Click flashlight on again, after 12 blinks switch flashlight off. Now it should be 100% only.
With the light on tap the switch button repeatedly until it stops flashing.
When the first flickering “buzz” happens tap the switch again. This puts it into config mode. It will start counting. One flash then a pause, two flashes then a pause, three flashes then a pause, etc. all the way up until it counts out 12 flashes. Click the light off during the pause after 12 flashes. When you turn your light back on again it should be in mode group #12 which is simple on-off. Hope that helps. It takes a few tries to get used to doing it but it’s much easier once you get the hang of it.
Edit
Dang it! Jos beat me to it.
Edit Edit
How cool is to belong to a forum where people race to be the first to jump in and help another member? :+1:
Thanks a million. It worked at the first attempt. Although I really don’t know what I did, but got the desired setting, so don’t care. Thank you Jos and I am also really grateful to everyone on this wonderful forum. It indeed is a privilege to be a part of this family. Thanks again.
I tried heatshrink tube today on the clip in another light mod and it worked!
I also used in the S2+ tan and works fine, doesn’t leave the scratches it once did
I just remembered what we talked about before and wanted to share!
Just receive my parcel, the flashlight is gorgeous This is my second Convoy S2+
But what does BATTERY CHECK mode means? It just blinks 3 short times, then again and again - and nothing more.
Ugh… once again you guys made me buy another flashlight…
I was walking around with my old S2+ (Blue XM-L2 T6-3B 7135*4) last night and admired how comfortable it felt in my hand. It is such a great EDC light. So now it’s going to have a younger brother - Desert Tan XPL HI U6-3A 7135x8. Can’t wait to get it.
In the third row: shouldn’t the “Enter into the first mode” box read “(if the mode memory is off)”?
For clarity, I would also change the “Enter into next mode” box to read “Enter into saved mode” or similar. The current text almost makes it sound as if the light has Next Mode Memory, which is a different system (and one just about everyone seems to hate).
