8-Pack AmazonBasics AAA Rechargeable Batteries - $9.99 [USA Only]
AFAIK, these AmazonBasics are rebranded Eneloops, so they should hold up well.
yeah for all i know, maybe they all do that — lose the LSD capability gradually — or maybe my camera is just overly picky
those same batteries are still ok in flashlights or kid toys
but digital cameras are famously picky
wle
These are good batteries. They perform just like the Duracell and real eneloops. Can’t tell any difference. Same capacities on testing as well
Thanks, got a set on the way.
Arrived today.
Black Basics, Made in Japan. Have 201704 inscribed.
Thanks again.
I thought the black ones are supposed to be the higher capacity ones… equivalent of Eneloop Pro? Or is it the grey ones? Amazon has been changing wrapper colors quite a bit over the years… can’t keep up.
Do you have an analyzing charger to measure their capacity?
They are Minimum 750mAh as shown in the OP link on Amazon.
Entire label is black with white lettering, Green ring at top. No other coloring.
Same as the last 2 pruchases I have. Never got the White ones.
Dont be offended… Just not been a good day.
Yes I do have a charger to check the capacity but I really do not see the need to. It’s an Eneloop for $1.25ea… get some. Still $10 for an 8 pack.
No worries. I was just curious. Thanks for the confirmation.
Never can have enough good AAA's. Ordered some. Thanks for the alert raccoon city.
The black label is just Bezos’s marketing department.
“Ooh, people know black Eneloops have higher capacity, let’s paint our regular ones black …”
Note the main page says “Packaging may vary”
Is the country of origin labeled on the package for the black-with-green Amazon cells?
PS — even trickier — when you hover the cursor over the various different size packages, all the popup illustrations show the black-with-green cells, not the white ones pictured on the main page.
Hmmmm …. “for more information search for B00CWNMXQW” says the fine print in the packaging image.
That brings up two items: Amazon Basics and the YCDC brand NiMH cells.
But then Amazon’s higher capacity ones (equivalent of Eneloop Pro) are painted grey, so go figure. :slight_smile:
Received my order yesterday. Cells were black topped and black wrapper with green band near the positive end. Says made in Japan and HR3. Has date stamp of 201704. Discharged tested 4 cells at 300mA right out of the wrapper (Used a Li-500 which first charges the cells). Capacity measurements ranged from 766 to 794 mAh.
Not sure I follow the above. Can I be confident that these are truly LSD cells?
EDIT: Read. Seems I can trust that these are indeed LSD cells. Thanks again for the alert RC. :)
No problem!
So cheap! Not like made in Japan
huh? Ones I got are made in Japan.
yes, that post was worded in such a bizarre manner, but I think he’s saying that usually Japanese produced items are more expensive than average, so if the cost is cheap it’s “not like made in Japan”
please feel free to chime in and elaborate
Thanks, raccoon city!
I don’t have a whole lot of applications that use AAA cells, but I couldn’t resist the sale.
Capacity at first discharge cycle seems good.
got some, thanks RC!
Hmm, sale’s still good, just ordered a set. Tnx!
They also have the 2000mah AA’s (1,000 cycles) 8 for $13.97. Ordered some of each. Thanks.
