✜Banggood deals≫ NC TUP ⚡Rofis TC1⚡$23.06⚡S41S ★★★ $34.65 BLF GT mini ★ ⚡ Fitorch P25 QUAD LED 26350⚡X1R angle light ★BLF GT70★
Banggood 11th Anniversary promotion calendar (click on links to see the details):
  • MON
  • TUE
  • WED
  • THU
  • FRI
  • SAT
  • SUN
Update: flashsale ended. Use coupon code 2017FNL to lower price to $24.50
Astrolux S3 XPL-HI 1400LM EDC LED Flashlight 14500
is now in flash sale for only $23.95
This is the most pocketable thrower out there with over 1000lm possible with decent high current battery (to get highest light output spring bypass might be required).
Two LED tints are available: 1A(cool) and 3B(neutral), driver uses Bistro firmware developed here at BLF, turbo mode is direct drive (through FET), low modes are regulated by 1xAMC7135. Lots of mode configurations to choose from (driver is programmable).
Astrolux S42 4xNichia 219C/XP-G2/XP-G3 A6 2023LM Rechargeable Mini LED Flashlight
is in promotion for VIP accounts:
VIP2
VIP3
VIP4
VIP5
$24.95
$23.95
$22.95
$21.95
What’s more it’s still possible to lower the price further with BG points!!! Prices can be as low as in table below(provided enough points is available):
VIP2
VIP3
VIP4
VIP5
$20.96
$19.88
$18.82
$17.56
Additional 18650 body tube available here: Astrolux S41/Astrolux S1/BLF A6 LED Flashlight 18650 Body Tube for $3.29 or with BG points for:
VIP0/1
VIP2
VIP3
VIP4
VIP5
$2.80
$2.76
$2.73
$2.70
$2.63
ThorFire TK15S XP-L2 1050Lumens 6Modes EDC LED Flashlight 18650
using coupon code a0f9a1 price will drop by -$11.60 to $17.39
Very detailed review by SoCalTiger here:
[REVIEW] Thorfire TK15 & TK15S (XP-L2, 1x18650) (Pictures, Output, Beamshots, etc.)
ThorFire TK15 XP-L2 1050Lumens 6Modes EDC Tactical LED Flashlight 18650
using coupon code 025a62 price will drop by -$10.80 to $16.19
New Ampcore Plus USB cables are now in preorder with great prices.
Those new version cables have metal plugs and are kevlar reinforced, cable organizer is included.
BlitzWolf® Ampcore Plus BW-TC8 3A Kevlar Durable USB 3.1 Type-C to Type-C Charging Data Cable 3.33ft
1m/3.3ft USB 3.1 Type-C to Type-C | $7.49 now in preorder, normal price $9.99 after preorder.
LUMINTOP IYP365 Brass Nichia 219BT/XP-G2(R5) 200LM 3Modes Portable EDC LED Penlight
Coupon code available now!
» :email:Request via PM here«
LUMINTOP IYP365 Titanium Nichia 219BT/XP-G2(R5) 200LM 3Modes Portable EDC LED Penlight
Made with titanium with brass ring inserts. Both high CRI Nichia 219BT and cool white Cree XP-G2 R5 bin available.
Coupon code with nice discount available now!
» :email:Request via PM here «
Astrolux K1 Stainless Steel XP-G3+365nm UV+Red LED 250LM USB Rechargeable Mini LED Keychain
New keychain light now in preorder for $14.75 (only 200 pcs for that price).
Compact stainless steel construction, USB rechargeable, white + UV 365nm + red LED, max 250lm (Cree XP-G3 white). Four colors to choose from.
Do you have a deal on the BLF X5 or the astrolux S3 under 20 usd?
Any chance for NW or high CRI models
Extra 25% OFF 2017 LED Flashlight Anniversary Pre Heat
Only flashlights from the above list can use 17FLANNP coupon code. Collection includes almost hundred flashlights, batteries and chargers from leading brands.
Note: some flashlights have better discounts using dedicated coupons - remember to check list in original post first.
Nitecore TIP 2017 XP-G2 360LM Metallic USB Rechargeable LED Mini Keychain Light
Using coupon code TIP11TH price is $19.46 (instead of $29.95, 35% off). Limited offer - only 300pcs for that coupon.
IMALENT DN70 XHP70 3800LM 26650 Tactical Rechargeable LED Flashlight
Using coupon code DN7011TH price is only $57.17 (instead of $109.95, 48% off).
Coupon limited to 150 uses.
High quality hight current Imalent battery and holster included.
I have no info about such plans at this time. I will try to find out more but I would not hold my breath :wink:
Klarus XT12GT XHP35 HI D4 1600LM Magnetic Charging Tactical Ourdoor LED Flashlight
Using coupon code xt12gt11th price drops to $64.67 (instead of $113.46, 43% off). Offer limited to 150 pieces.
LED: XHP35 HI D4, dual tactical switch (both on tailcap), switchable tactical and general purpose/outdoor modes. Range exceeds 600m (650yds).
Magnetic charger connector and quality 3600mAh cell included.
Original Xiaomi LED Smart Table Lamp Dimming Reading Light For Cellphone
is now in promotion for $38.99
  • Bluetooth 4.0 smartphone controlled
  • 2700K - 6500K adjustable color temperature
  • 300lm
  • 6W power consumption (100-240V 0.2A)
25% off for Klarus brand
Coupon code: BRANDKR
10% off for all flashlights and lasers using coupon code 11annvlight10%
Good for something fanciful for which no other coupon codes are available.
