In theory, I prefer my lights to have mode memory so that I can set it where I want it. But, in reality, I nearly always use the shortcut to Moonlight and go up from there when using my Olight S1A Baton. I never use the mode memory.
For me, in this size light and always running LSD NiMH cells, starting in moonlight is perfect!
Is it made of Titanium if yes… drooling
Nice, but I need better perfomance for the AA NiMH……
Yes.
Then count me in, I take one.
List started? I’m in.
I like my Reylight Pineapple, and this light seems to be the same internals but a different body. But, yes, I wish the output on AA was a bit greater. I know you’re not going to get high output from a AA light with a Nichia 219 LED, but 200 lumens should be fairly easy. I guess they designed it more as a 14500 light.
imo
200 lumens is not easy for a 1.5v battery.
for an AA or AAA light w Nichia, a 110 lumen high is normal and reasonable
any AA light you can name that does more than that, does it for 3 minutes or less and then steps down
If you really need 200 lumens, step up to LiIon (3.7 volts)
this is in reference to the previous TiLan:
the middle and maximum levels use PWM for dimming (at a reported 9KHz for the frequency). I did … notice it …. I don’t know why it is used in max mode
My question is, does the new version still use the same PWM?
I also wonder how the buy will work, I have no Facebook, so I am out of it?
The Manker T01 will do over 400 lumens on a AA, without any step-down (using one of the special modes that prevents the step-down). Granted, it does get hot, but it seems to handle it okay.
The Zebralight SC5 will do over 500 lumens, albeit with a 3-minute step-down.
I’m not sure what that power would translate to in a Nichia 219C, but it’s probably somewhere around 300 lumens. I’m happy with a step-down to prevent overheating.
But, yeah, that’s kind of leading-edge for 1xAA lights.
Anyway, I’m not really concerned, since I don’t use my Pineapple as a bright light. It’s used as a bedside light, and it does a good job in that function. I suppose I could use a 14500 to get the higher outputs, but I have other lights for that.
Good question, but I presume the answer is yes, because it doesn’t sound like this version has changed the driver. The Pineapple has PWM on all modes. It would benefit from using higher frequency PWM, if it can’t go constant-current.
It is only a few manufacturers who manage to make good boost drivers for AA cells, and of them Manker is the most affordable. The new Manker E03H AA-headlamp manages to get 240 lumen from a 90+ CRI 4000K 219C (350lm for a cool white XP-L). I doubt that it runs on a 14500 btw, the specs do not mention it.
I agree, different lights fill different niches. The LAN does a very good job of offering both High Lumen or High Runtime options
I think it is a very good looking light, and has a lot going for it, including being dual compatible w both Primary and LiIon power. I especially like that the moonlight stays at the same low level on both types of power. The PWM helps maintain consistent High CRI Tint, all good things. I like the trit options too…
I also like the teardrop design elements in the head, a bit like the LunaSol
the head also reminds of Muyshondt Aeon. The TiLan also shares a body design element similar to the Flieger…
Imagine owning a titanium light, not for $600, not for $400, now you can have it for less than $100! Buy more than one
My last AA lights are Utorch UT01, Manker E11, Klarus Mi7, zebralight SC5 MK II, EagTac D25A, Olight S1A…. sorry, but I do not think that 200 or around 180 lumens are strange thing…and not for only 1 minute…. 110 lumens is fine for a flashlight AA NiMH of 3 or 4 years old…but not for 2017…… and for 100 lumens now we can see without problem 2 hours or better…
Ok, we can not hope the same data for nichia, but I think that will be great better perfomance.
(In any case I have bought one of the Rey Light brass, and I love it… )
When getting a lot of power from such a light, you should also consider the thermal properties of titanium which are a lot worse than those of aluminium.
At least a continuous power of ~2-3 Watts seems to be the limit, 3-4 Watts would be too much for such a design in titanium.
This is probably the best AA Titanium light out there!!
Yes is one possibility…or perhaps is this
You will have to try both to make sure ….
@Trevi
Could you please make a full review of TiLAN?
I am interested too. Do you have access to some trits and options to put some on as your previous lights?
I already contacted OP, but so far the buying process seems “grey” to me
