Yes, we have hundreds on the way.
We also ordered more Aspire 18350s about three weeks ago, but I haven't heard anything about shipment yet. I am checking up with them (they were slow last time too).
Richard,
Is it possible to get the 30mm FET+7135 Driver – 2S Momentary – Convoy L6
with the D4 firmware?
you may also choose the TA 8+1+FET with NarsilM
I got 2 of em here right now
can be configured as you wish
vwpieces:Richard, Is it possible to get the 30mm FET+7135 Driver – 2S Momentary – Convoy L6 with the D4 firmware?
you may also choose the TA 8+1+FET with NarsilM I got 2 of em here right now can be configured as you wish
Added D4 as an option on the 30mm FET+7135 and got it all tweaked for 2S. If there is enough demand for Narsil, I will add that as well.
Smittymojo: RMM: Newlumen:Hi mtnelectronics, i was told shockli 26650 5500 mAh in button top are available. When will you stock them? Thanks.
We have already had two batches of them come and go, and we are waiting for another batch to arrive.
Richard, Just want to confirm you are going to get some more of the button top Shockli?
We also ordered more Aspire 18350s about three weeks ago, but I haven’t heard anything about shipment yet. I am checking up with them (they were slow last time too).
Sounds good, I’ll keep an eye out for them.
Thanks
Lexel: vwpieces:Richard, Is it possible to get the 30mm FET+7135 Driver – 2S Momentary – Convoy L6 with the D4 firmware?
Plan on putting this in my S70S. Any forceen problems?
RMM: Lexel: vwpieces:Richard, Is it possible to get the 30mm FET+7135 Driver – 2S Momentary – Convoy L6 with the D4 firmware?
None that I can see except the size. The S70s is smaller than 30mm, but I can’t remember exactly what it was. 27mm or so.
What did you have to change for 2S? Could I get a copy?
From what I recall, it didn’t have code to handle voltage measurements on 2S, or at least the comments suggested that it might not work (and I didn’t try it).
Just a heads up: we have more D4 that came in this morning and we are going to be finishing up testing in the next few hours, so look for them to hit the website later this evening.
Thank you for posting this Richard. I saw it and was able to make an order later that night for a green Nichia version. It was shipped the next day and received yesterday, so I had time to mess around with it over the weekend. Thanks again for such prompt and thorough service!
I honestly didn’t get all the hype behind this thing. I understand now…
RMM:Added D4 as an option on the 30mm FET+7135 and got it all tweaked for 2S.
What did you have to change for 2S? Could I get a copy? From what I recall, it didn’t have code to handle voltage measurements on 2S, or at least the comments suggested that it might not work (and I didn’t try it).
Enable volt_mon_pin7 option, add tk-calibWight.h header, define 360K option, change ramping level tables, fix a few other broken references in the code. It's not clean enough for you to see it yet, but it is working. Let me get to cleaning it up, then I will share it.
In NarsilM you also have to disable Onboard_LED line
Richard, I read that you are ordering some S2+ hosts in desert tan and clear, but will you be stocking the desert tan flashlight with Biscotti?
Perhaps at a future date, but not in this order.
Can you add this to website please.
Priceless!
(Remember, it is actually Richard’s wife Lisa that prints that receipt… just sayin)
Lisa says the price is $7.95.
Oh that’s too cool!
Any idea if/when any 1.6mm thickness drivers will be in stock again for 17mm or 20mm diameter?
Will you get any convoy s2+ holsters…? They seem to fit the D4 well…
Do you have a fet driver that will run an xhp 70.2 in a convoy l2?
The 20mm should have some. The 17m FET driver is only 1.6mm, and it is an option for the 20mm FET+7135. 17mm, I am not planning on any, at least not for a while.
