So, where can you get it?
“750meter throw” now you got my attention
what about the price?
I wonder if there is going to be an MT03S as well… in 4S configuration instead of the current 2S2P.
The effect in dark seen close to a car headlight, how much is it ?
Double brighter than car light. MSAP is 65usd~69usd
MT03 is not going to make a smaller version, considering the huge heat from 10 000 lumens MT03 size is good for heat sinking
how about triple XHP35 HI?
Really excited to see this new version. Will there be a model with cool white led?
Could someone clear up the specs on this light? Is this light 4500, 5000, or 5500 lumens and is the max throw 500 or 750 meters? Thanks.
looks good!
what you mean ” no step down”, the light maintains the output even it reachs 100*C ?
CW 5000lumens; NW—4500lumens. KCD shows 550meters distance
If you shut down the thermal control, the output will maintains even it reachs 80 degree C.
i like your flashlights mostly (tested 3 of them)
but idea to put XHP with SMO is strange.
i mean XHP performs best with OP.
may be you guy thought about XPL-hi or L2 there? good old decisions for throwers.
anyway, i`m glad to see that you keep on doing new stuff.
i like your flashlights mostly (tested 3 of them) but idea to put XHP with SMO is strange. i mean XHP performs best with OP. may be you guy thought about XPL-hi or L2 there? good old decisions for throwers. anyway, i`m glad to see that you keep on doing new stuff.
It's XHP70.2, not XHP70. The XHP70.2 performs well with an SMO - if focused well, cant see the black hole, and throw is definitely better. In fact if you are interested in max throw, we've been using SMO's with the XHP70 in the past. Now pretty much we are all switching to the XHP70.2.
but idea to put XHP with SMO is strange.i mean XHP performs best with OP.
may be you guy thought about XPL-hi or L2 there? good old decisions for throwers.anyway, i`m glad to see that you keep on doing new stuff.
I’ve got some 70 vs 70.2 in an L6 with SMO comparison pictures here.
The new 70.2 does have less of a donut hole pattern. It’s not gone completely, but much better than the xhp70. The first 2 photos below are a direct comparison of the 70 and 70.2 on my L6 with the same reflector height. [image] [image] . If I move my reflector away from the emitter just a little, the donut hole reduces more. See below. [image] Now when you look at these lights without the lower exposure, the donut shapes are much harder to see. The hotspot of the 70.2, which is shimmed ou…
If you look at the darker shots you can see the improved beam pattern of the 70.2. The dark hole is much reduced. When viewed at normal brightness levels the 70.2 appears very smooth. I got 830 meters on my light and I know my numbers are a bit lower than average.
mrheosuper:what you mean ” no step down”, the light maintains the output even it reachs 100*C ?
woah, there is a chance i can boil an egg with this light, i guess
Hi
My MT07S stopped working after one day.
Work dwo modes, in one flicker, I can not turn off the flashlight.
The flashlight (the reflector) probably I see smoke rising.
What could be damaged?
