Yes will do!
The Miller, what does that mean for the q8? Is it to be put on the back burner until after the busy season?
Q8 is build by a different manufacturer, so there are no links between the two projects. Also, Q8 is afaik already in production (at least a first batch)
Legal 710 I understand all about that. The Miller made a post about it on the previous page so I thought it prudent to ask for clarification in the same thread. Thanks
Please add me to interest list. Thanks.
The Q8 is being made, but from both Thorfire and Lumintop it is clear seasonal production is a real factor, so this means I do not expect the FW3A of which the CADs are talked about can be done fast (unless of course LT sees it as a good addition for the busy Q4 but don’t don’t count on it, we want it right so rather a bit later
Add me to the interest list. Thanks.
Yes will do!
And welcome to BLF!
Please, i want one too. Thank you.
The 10511 has a solid surface as compared to the cup like indentation in the more common 10507. If you’re not using a glass lens to cover the optic, dirt and lint can gather in those insets in the 07.
This shot from Cutter shows it pretty clearly, the 10507 is in the back…
There is another week-long holiday (Golden Week) starting Oct. 1st that won’t help things (from our perspective, anyway).
I’ll take one.
Any idea of peak lumens? Usable constant lumens?
And any beamshots? I admittedly did not look through all 30+ pages.
Also this flashlight would likely require a high drain battery right?
Sorry for so many questions lol
Unprotected cells only, due to length. That’s the only question I can answer for sure.
I have a lens over my 10507, and according to the specs the FW3A does too. But I’ve definitely had lights with a bare non-flat optic, and it gets annoying trying to keep it clean.
Please add me to the FW3A list. Thanks! Charlie
Welcome to BLF!
Hard to say max output and max long term output.
For the Q8 we kept on saying 4K lumens , we wrote 5K in the text for BG listing, yet with right cells it does more.
Here the same, for now we say 2500 lumens max but we do expect it to be a bit higher
Long sustained output, we can say more when more testing is done.
Thanks. I like what you all are doing here.
Glad to hear the news about the manufacturing! This will be a cool light!
Thanks.
Yeah a cool little hot running light but Narsil is very useful in finding a brightness level that does not overheat things
Please add me to the interest list, this is the first BLF light that might knock my modded EE A6 out of the running for my main EDC.
