Double bravo!!
CRX, I’m looking for ways to hang my D4 in a tent.
Slightly loose o-ring seems to be the best option so far. What size did you use and how tight was it?
Another reason I like to install magnets in my lights and other stuff is because I have a couple large neos stitched into pieces of fabric to the top tent pole sleeve underside of my tent so you can just stick stuff there like lights, small USB fan, radio etc.
I also have a line of paracord running along there too for stuff with clips, but anyway the o-rings I used for a tight fit are about 18-20mm x 1mm, nitrile or other firmer material is best as silicone is too soft and will pull out of place easily but for your needs maybe a soft 22-24mm id x 2 or 3mm would do or make a thin piano wire type clip. Don’t be hanging the D4 in a tent on full power though…
Excellent mod sir! I love the o-rings in the body grooves for grip. I’m buying a bunch a o-rings today for my light grooves in all my lights. I bought this light and have really enjoyed showing it off to my buddies. They can’t be.ieve something so small can be so blazingly bright. Some are planning on buying their own. Thanks for the great info and ideas. :+1:
Could hurt the eyes; other than that, TK will come and restrict the output to some stable level.
Thx for suggestions.
Oh man that looks awesome. I completely missed the carbon fiber on the bottom until Dale voodoo’d the picture. That is one awesome looking light. I wonder if the magnet would be able to hold the 18500 version horizontal?
I think you would need a 22mm x 2mm magnet in there for the extra weight :+1:
How did you do the “GITD material around the switch”.? it looks perfect, as does all your mods, very nice…
It took a few attempts to get the right size and was tricky to do but it is just a thin strip of sticky GITD tape cut with a scalpel and pressed into the gap between the rubber switch boot and steel bezel, so it’s just the top part showing.
Well, we’ll give it a go, thanks for explaining. Green GITD material around the switch should look good on my d4 black and grey, but not sure on the green d4. What do you think ?
I think the green looks good
Yes the green looks good. Thanks for the pics.
How did you get a smooth tube shorty…? My shorty looks like the one on the far left pic. I must have missed those other options…
Does the switch ring thread in or is it press fit? I didn’t remove it when I took mine apart and replaced the FET….
@CRX sorry for the noob question, but what recessed switch did you use as it look almost completely flat with the “wide” portion for the GITD film. Also you mentioned the bezel when titling the photos. Did you re-use stock bezel or replace? Will be taking delivery of my D4 tomorrow and have a few items that are on the list for mods, the recessed switch being one of them. Thanks.
Awesome!
That’s OK mate, sometimes I’m not the best at showing or explaining things unless asked.
For the switch I used a very thin flat head screwdriver to slip under the bezel and twisted to raise it a bit then pryed until it popped off, being careful not to press on the switch when prying, don’t want to damage that.
For the recessed switch it is just the stock switch in there but to replace the rubber I cut three pieces of GITD tape to size, punched two in the centre with a 7mm punch to make doughnuts and stuck in the hole then placed a 1.5mm round piece of gorilla tape on the momentary switch for the contact plunger and put the last GITD disc on top, filed down the underside of the steel bezel a little, maybe 0.4-0.7mm then put some silicone around the inside edge of the switch well and pressed the bezel back in place with a protected vice then finally an 8mm disc of black stickyback plastic in the centre to create the glow ring.
It will take some trial & error to get the right sizes etc but you’re just wanting to replicate the underside of the original switch boot. I did consider just slicing the top off the original with a razor but don’t know how that would work out.
When I mentioned the bezel I meant I had cut a thin strip of the glow tape, maybe 2mm and stuck it to the inside edge of the flashlight head just above the MCPCB so there is an afterglow seen through the optic when the light has been on.
Don’t attempt the switch mod unless you are fairly confident of success as most likely you will trash the original rubber boot, scratch the steel bezel or body or damage the switch. Best to have the light in your possession for a while before modding Hope this helps :+1:
Thanks for the comprehensive write-up. The D4 is my first foray into the “custom” flashlight world. I have only had ArmyTek Wizard Pro’s up until this point. I will go ahead and add the glow material in the bezel as that is an easy thing. I have added a magnet (3/4”dia x 1/16”thick N52) to the tailcap and it works ok with the smaller 18350 tube mounted horizontally. I wish I had a lathe to turn down the tube threads so that I could fit a larger magnet in the 18650, which I prefer to the 18350.
I will wait on the button mod for now, although I think that it might be easy enough to add the glow material below the rubber switch boot with some cut-away sections in the boot to reveal the GITD under neath. If I could get a spare boot, then I would be more apt to try sooner.
Great looking light you have there. Certainly one to aspire towards and inspire others :+1: :sunglasses:
Cool, thanks. I considered filing down the tail threads some by hand but I never seem to get it perfectly straight
Just be sure to keep waterproofing in mind if you go altering the switch boot.
Yeah the D4 is a good light, not meant to be run on full pelt all the time but I like having the power there, suits my needs of very bright light for a few seconds at a time in a very compact format.
You seem like a good chap so let me know if you need that spare boot in a few weeks
