Ted, I went with a China made military type with shock cords on the ends from ebay for the L6. For the GT I’ll go the same route. It was ridiculously inexpensive @ $10 or less from what I remember. They had them in various colors.
I just looked them over since I need at least 3 anyway. This is what I bought. >>>>click here<<<<
The rest of the inexpensive ones with free shipping only had one buckle and they will slip, so you want 2 buckles per end. Buy 3 and get 15% off. Put four in your cart to get that deal. So I have a spare. No big deal.
Been very busy at work, so I haven’t been here for a little while. Checked messages and didn’t see any new ones and was wondering what the status was on this bad boy ?
I live in the Netherlands too. With DHL your are always charged for tax. DHL is very strict with that. But with Chinapost for example, most of the time you don't have to pay any tax.
I hope it’s ok to show these images.
These are taken from the latest CAD files from Lumintop.
Here is a render from the light included knurling. (first time making a render) (clickable)
And here is the newly designed battery carrier. Keep in mind these are just images from a CAD file(!), so the real version can be different. (clickable)
All of the direct comparisons I have seen with the XP-L HI and XHP35 HI have had the results be virtually the same. Including my own testing. For example I have 2 Convoy L2’s here. 1 of them is an XP-L HI, the other is an XHP35 HI.
Which one throws further is more a matter of the exact battery charge level but generally the xhp35 comes out slightly ahead. The lumen and usability race always goes to the xhp35 though, it has almost twice the lumen and almost twice the hotspot size.
That mcpcb should technically fit I suppose but you would most likely need to make some new holes for mount it. Also it is a 6V mcpcb, we need a 12V mcpcb for the GT, this is the primary reason for the new mcpcb.
The only other DTP option for a 12V xhp70 is the 20mm sinkpad. That would require a fair amount of extra work to make it work, and not something lumintop could put into proudction if it works out.
