DQG Tiny 4th 18650 xml-2 review
125 posts / 0 new
ReManG
Last seen: 9 hours 48 min ago
Serp,
That is a fantastic mod! Thanks for the great photos and especially the links to the parts you used!
Serp
Serp's picture
Last seen: 7 months 2 hours ago
I do not like only a small gap between the bezel and the housing
http://forum.fonarevka.ru/album.php?albumid=1062&pictureid=15681
ReManG
Wabi Sabi
That gap is only a small flaw in an excellent build, take the excellence, accept the small flaw… Great work…
I am still too chicken to do more than swap TIR’s in mine…
Dutcheee
Last seen: 4 days 3 hours ago
Nice job Thumbs Up
What driver did you use?
I think your heatsink (is it thermal glue?) is a bit too thick. The top of your carclo sit’s a bit too high for the gap to close on the bezel. Does the carclo slide all the way down? I had to sand off the edges a bit.
Or maybe you can sand down the heatsink. Or the noctigon board a bit, but that is not really nice for the already limited heatsinking maybe.
Or place an (O-)ring to fill the gap.
I don’t know these nichia’s you used. Tint looks nice. Is it bright?
I’m looking to mod a second one with the new noctigon board with the small added pad for a locator led and high cri nichia’s. Someday Facepalm
Worked out nice for you! It’s really my favourite small powerhouse.
Really nice job.
Serp
Serp's picture
Hi Smile
Original. Wires are soldered in place of the LED. I removed the LED on the soldering station (hot air 240С)
http://forum.fonarevka.ru/album.php?albumid=1062&pictureid=15303
No thermal glue, only termalpast.
Optics sits right on the edge. In addition, Im made a pit under it
http://forum.fonarevka.ru/album.php?albumid=1062&pictureid=15683
triple rests on a support of aluminum desired thickness
http://forum.fonarevka.ru/album.php?albumid=1062&pictureid=15304
http://forum.fonarevka.ru/album.php?albumid=1062&pictureid=15253
Not bright. I’m like it Smile
It’s warm white led (2500-2700K)
0,01А-0,25А-1,05А – after change SMD resistor R35 for R50
Turbo 2,25А
http://forum.fonarevka.ru/album.php?albumid=1062&pictureid=15254
wle
wle's picture
Last seen: 1 day 42 min ago
i have had one for about 9 months
used normally
last week the switch broke off the circuit board
kind of a bad design
pushing the button strains the 4 solder joints every time you press
be prepared for it to not last forever
i emailed david, the creator, he seems sympathetic but does not offer help
so far
i can post a link to pictures of the break
wle
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
wle
wle's picture
i used to be a fan of this light
but i have had one for about 9 months, normal use, and the switch just broke off the circuit board
this is a weak design
every time you press the button, it stresses 4 tiny solder joints holding the switch on the board
sooner or later it will fatigue and fall off
wle
-Greg Lemond.
ReManG
Wle, that is good to know, on the III version, the switch is body mounted, and mine is still going strong. I use the IV version as a back up anyway.Thanks for the update!
wle
wle's picture
body mounted might fix that problem, the IV has it on the circuit board, at the worst possible angle
i’m going to fix it with a switch made of 2 wires in the air, that the button can press together
wle
-Greg Lemond.
mikeyx
Last seen: 2 months 14 hours ago
It looks like a drop or two of epoxy between the body and the switch would also solve the problem.
Mike
wle
wle's picture
the force of pushing the button would then be held by the epoxy – IF it stuck and did not also get tweaked loose by button pressing…
wle
-Greg Lemond.
Stereodude
Last seen: 11 months 6 days ago
I have a few questions about the DQG 18650 Tiny 4th that I couldn’t find answered anywhere.
1) Is the driver in the light really constant current regulated? That doesn’t seem possible since the driver board seems to lack an inductor (though I can’t find a picture of the bottom of the PCB). At best it seems like it can maintain constant current only as long as the battery voltage stays above Vf using linear regulation or high speed PWM control (though I didn’t see a MCU either). The CNQG page, just says “Current Regulation”. I didn’t see any runtime vs. output graphs anywhere that would shed more light on this.
2) Can it fit protected 18650’s that are ~70mm long?
Serp
Serp's picture
No, it’s linear
Chip Qx7137 http://www.go-gddq.com/upload/2015-09/temp_15090911368037.pdf
http://forum.fonarevka.ru/picture.php?albumid=1062&pictureid=15208
wle
wle's picture
WARNING
the switch design is very bad
mine just broke off
at the SAME TIME it also failed, so i could not even solder it back
i had had it about 8 months, daily use but nothing extreme
i emailed the company dude, ric, he did not seem to care
wle
-Greg Lemond.
wle
wle's picture
WARNING
mine broke off inside the light, after about 8 months of reasonable use
AND at the same time, it quit working, so i could not even solder it back
emailed company head, ric, he did not seem to care
(near the letter “K”, is where it SHOULD be)
wle
-Greg Lemond.
dw911
wle wrote:
WARNING
wle
!https://c5.staticflickr.com/9/8835/28776883092_b3df40509d_z.jpg!
Same thing happened to mine with only a few weeks of moderate use, bad design the switch could of done with maybe some glue from a heat glue gun or similar behind to hold it rather than reliance on just the 2 solder pins to hold it in place. shame as I liked it alot
wle
wle's picture
i think it uses 4 solder pads, but still this the WORST design.
all of the force of pressing the button goes to bending it back.. it is bound to fail
sorry to say
but i did like it
i bought another one when gearbest had them for $14, has not arrived yet
manker u11 is a better light, just bigger and heavier…
wle
-Greg Lemond.
hank
hank's picture
Last seen: 7 hours 16 min ago
Cross-reference on the switch failure, as there’s a separate thread for that also:
http://budgetlightforum.com/node/49297
Serp
Serp's picture
wle wrote:
WARNING
mine just broke off
Yeah. My button is too broken today.
it’s like KLS7-TS3606 (3*6*5mm, horizontal) , SWT-11, TS-1135HS-180-003
When I tried to make a FET-modification of the driver.
Button badly soldered. Or it is because of lead-free solder.
I will add one FET transistor in parallel to the one that is responsible for the turbo mode (AOFV). Gate will be on 6th leg of microcontroller.
I could still change the transistors on the board for the best, with less resistance
http://s019.radikal.ru/i611/1612/cc/b73b1b0f7673.jpg
Pete7874
Pete7874's picture
Last seen: 45 min 21 sec ago
Does this flashlight have any kind of low voltage notification such as blinking or auto shut off? Trying to understand if non-protected cells are OK or if it’s safer to use protected ones in it.
Dutcheee
The stock light has no protection for low voltage.
If it dims, switch battery or check it from time to time.
Or mod it Silly
Pete7874
Pete7874's picture
Is a faulty switch a common issue with this flashlight? I just received mine today. It worked fine the first couple of times, but now it only works sometimes. It either will not turn on or will not turn off or will not switch to a different mode most of the time. Is there an easy fix?
Edit: just found the warning thread related to this issues. I should have done more research before buying this junk.
Pete7874
Pete7874's picture
Ok, so if I push up (toward the lens) on the switch button, it works. But if I just press straight down on it, it does not work. Is this normal?
wle
wle's picture
yes it is unfortuately something that can happen.
as i had warned.
the guy from DQG used to post on here, i am not sure what happened to him.
does anyone know?
i emailed him when mine failed, (2 of them) but no response.
it would be great if the light worked
to answer other questions, it is safe with unprotected cells
what it does is step down levels until it gets to the lowest one, that one will blink to say things are getting low, then eventually it cuts off, protecting the battery
not sure what level it cuts off at but it seems OK for that function.
wle
-Greg Lemond.
wle
wle's picture
Or mod it Silly
DQG tiny 18650 IV?
yes it does have protection, it goes to lower modes and eventually shuts off.
wle
-Greg Lemond.
Pete7874
Pete7874's picture
I just noticed in the OP photos that the head unscrews, but mine will not budge. Is there a trick to unscrew it or do I just need to eat some more spinach and try again?
wle
wle's picture
it does unscrew—may be locktited in or something
doubt it
just use more juice
it;s kind of hard to grab, thin on the edge
use a rubber jar opener pad thingy
wle
-Greg Lemond.
Dutcheee
Or mod it Silly
DQG tiny 18650 IV?
wle
I wasn’t aware or I forgot.. Big Smile So, what’s the cut-off voltage?
vresto
vresto's picture
Last seen: 1 day 19 hours ago
is possible to use for this flashlight unprotected cells?thanks
EDC-Amutorch X9 XHP50 nw,Sofirn If-25A cw
Headlamp-Thrunite TH30 nw
Pete7874
Pete7874's picture
Yes.
