Personally I would pick Panasonic GA’s for Giggles, they are my go to cells for everything. If you could arrange for these to be sent with the GT that would be great.
Since nobody has tried this before so one could only guess. If the XHP70.2 is driven to 6000 lumens, I would say the the light could possibly produce 250~300kcd (1~1.1km). The throw is still impressive not to mention that with the 6000 lumens output it is just a different kind of monster. I used to owned one of these generic 85W HID flashlights purchased from Aliexpress and the throw is about 200kcd, so this BLF GT will beat these HID flashlights in every way despite that the GT has a much bigger reflector.
My Convoy L6 with a XHP70.2 P2 3B and SMO reflector does 195 kcd, but pushed hard at about 18A and 8,200 lumens @30 secs, 9,000 @turn on. Driven at lower amps in a GT, would hope it would do at least 250 kcd.
The Test PM just went out to the team a few hours ago. Once all the back end stuff is sorted out on that we should be able to get the ball rolling on the down payment PM’s.
We are still waiting for the final pictures of the updates from lumintop before final approval, my guess is the prototype parts are in production and they will send the pictures once they are done.
Or what I usually do — one to use normally and one to use for development. Or one to keep stock and one to mod. Or one to use and one to give away. Or more than one just because the really good stuff doesn’t happen often and tends to only be available for a short time. It took me a long time to learn to buy more than one when I find something really special.
Although i’ll remind myself all those possible justifications i would put it more simply: if the stuff is good, more then one is better then one. Of course that’s true of about anything if you can afford it. :person_facepalming:
Now the test PMs worked, thanks so much to Mr.Scott and SB for doing it.
all as expected, so with the new core list, and a PM sstem that is working, Neal begin ready to process all the PMs and payments, it should not be long now.
Of course topic title will be changed to indicate the sending, a list of how the sending went will be posted and list of BLFers who made the down payment will be made by Neal and posted too.
Oh wow, spot 682 was empty, you should have been 681, really asy to correct this error
Oh gosh I SO hope there is no hype and people do thinfs based on real Info, it is one of the prime reasons to show the whole process and not do things like teasers .
We try to post info ASAP and clear, being open about flaws as well as the good stuff.
